Carb Experts, I Need Your Help!
Background: A few months ago I acquired a '71 4 speed coupe project car. It sat for 31 years before I got it, and after cleaning the fuel system, rebuilding the quadrajet, new plugs, adjust the points , etc I got it running. It ran very well! My goal with this car is some sort of resto-mod street cruiser. I have a 408ci small block shortblock that I am working to build up as I have the extra money. While I am working on that, I happened upon an old school 327ci that just kinda fell in my lap. I want to put it in and have something to play with while I build the 408.
This leads me to my first set of questions. I also got an old Holley carb to use with the 327 and some random assortment of jets, metering blocks, bowls, etc. I am pulling the #s matching engine on a stand and saving it, so I would like to leave the quadrajet alone and use the Holley I have. I found the list number on the Holley to be 3140-1. I have since found out that this carb is a 4160 style standard on 65-67 Chevelle 427 and Impala 396 engines. However, I am unable to determine which rebuild kit to get. Holley's website shows 4 kits for the 4160 style:
#37-119 a generic Renew kit for 4160
#37-1542 a generic Fast kit for 4160
#37-754 Renew kit for 750cfm 4160
#37-720 Renew kit for 600cfm 4160
How do I know which size carb I have? 750 or 600cfm? I did not see too many other numbers on it. Do I get one of the generic kits and hope all the correct gaskets are included?
Next question is, how do I rebuild this carb with my 327 in mind (jets, air bleeds, etc)? I know it will require a little bit of tuning once running, but what is a good starting point? The engine is an old school 327ci 11.5:1 compression, 30-30 cam, double hump heads with mild porting, and dual plane intake.
Any help would be greatly appreciated!
Would #67 jets work for a more radical engine? I thought your supposed to optimize jets for the engine needs.
Edit: I also have a List #3246 body and a List#3910 body. I also have some metering blocks and bowls that might match up. Would I be able to use the same throttle plate with different bodies? Whichever gives me the best combo?
The 3910 measures 1-3/8 primaries, 1-7/16 secondaries and 1-11/16 at the bottom where it would bolt to the throttle plate so it appears to be a 780cfm. That being the case, it does not look like I can use, or would want to use, the smaller throttle plate with the 3910. I have 2 metering blocks with power valve holes and idle adjustment screws, and 1 block with no power valve provision. I have 2 secondary center hung float bowls, and some misc brackets. I will have to get the numbers off the metering blocks to see if I can use them or not.
I think the complete 600cfm carb would be too small for the engine I am putting it on, but I can use some parts from it to complete the 3910. All I would need to buy is a primary bowl and throttle plate I think. Everything else should come in a rebuild kit.
Best kit out there.....
http://www.aedperformance.com/parts/...rt-4160-detail
Browse the site for other great small parts they offer.....you can really do I nice job with their stuff......it is all Holley bulk items.....but for like half the price. The bowl screws kits are a bargain too.
The Holley kits are great....but super pricey and you are left with a bunch of crap you will never use.
If you have access to an Ultrasonic cleaner....I recommend that as well.....I have a 9 litre unit and it is awesome for carbs and other things.....
I do a LOT of carb re-furbs for vintage bikes and cars. Just a suggestion.
Jebby
Jebby
As a side note, yes a 750cfm may be a bit big for the 327, but I am also building a 408 small block that will eventually find its way into the car and I plan to use the same carb on that.
As a side note, yes a 750cfm may be a bit big for the 327, but I am also building a 408 small block that will eventually find its way into the car and I plan to use the same carb on thgat.
