68 alignment question
Old Nov 23, 2015 | 11:51 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default 68 alignment question
I just finished some adjustment in ride height on my '68 and after lowering the rear, the wheels are now slightly tilted towards the inside (top of tires towards the inside)
On a factory aligned car, are the wheels straight or are they tilted towards the inside or outside?
Old Nov 24, 2015 | 12:49 AM
dugsgms74's Avatar
dugsgms74
From the factory they came with slightly negative rear camber(top of tire tilted inboard).
Old Nov 24, 2015 | 11:36 AM
GrandSportC3
Thanks.. thats interesting as I don't know how the tires woukd not wear more on the inside with that alignment unless of course the car would actuall lift up a little while driving as of course, the tires will tilt even more towards the inside under compression. I'm not a engineer, so I don't understand enough about the dynamics of a car when driving.
Old Nov 24, 2015 | 11:43 AM
toobroketoretire's Avatar
toobroketoretire
Remember the tires are supposed to be rotated every 5000 miles so any inside edge wear during the first 5000 miles would get offset by outside edge wear the next 5000 miles. I run mine straight up on all four corners to maximize tread life.
Old Nov 24, 2015 | 11:48 AM
Alan 71's Avatar
Alan 71
Hi,
Unless you REMOUNT the tires with the inner sidewall on the outside of the wheel, ROTATING tires has NO effect on the position of the tread relative to the car!
Regards,
Alan
Old Nov 24, 2015 | 12:30 PM
GrandSportC3
I got directional tires... they can only go on one way.. Furthermore, front and rear are different size.
GrandSportC3
Originally Posted by Alan 71
Hi,
Regards,
Alan
Right.. that makes sense.
Old Nov 24, 2015 | 01:00 PM
vetpace78's Avatar
vetpace78
I lowered mine all way around and set the camber a bit more aggressive then stock. I couldn't care less about getting a few extra miles out of my tires if it handles like it's on rails. I guess I didn't buy mine with thoughts of saving a few bucks. That's what my 92 lumina daily driver is for.
Old Nov 25, 2015 | 01:09 PM
GrandSportC3
Not really noticeable from other angles..
To 68 alignment question
