Strange clutch behavior
Old Nov 28, 2015 | 05:47 PM
ve69tte's Avatar
ve69tte
Default Strange clutch behavior
I have a 1969 small block. A strange problem has developed with my clutch this year. I think I will most likely replace the clutch during this winter anyway, but I would like to understand why it is happening. When I start the car and start driving, the clutch works perfectly, smooth release and smooth transition. After a while, I assume when the car warms up???, the clutch become very sticky and jerky making it difficult to release the clutch smoothly, especially from a stop in first gear. If I turn the engine off, the clutch movement is very smooth. So I don't think it's the linkage. Any ideas?
Old Nov 28, 2015 | 06:07 PM
toobroketoretire's Avatar
toobroketoretire
I would think your flywheel needs to be resurfaced and a new clutch and pressure plate installed.
Old Nov 28, 2015 | 08:38 PM
vette_jim's Avatar
vette_jim
Yep
Old Nov 29, 2015 | 01:21 AM
Kim72's Avatar
Kim72
My guess. A broken spring on the clutch disk. I've experienced this before. Makes the clutch chatter badly from a standing start.
Old Nov 29, 2015 | 10:11 AM
ve69tte's Avatar
ve69tte
Thanks for the reply. But wouldn't I see this problem all the time if it was the flywheel, and not just after driving for a while?
In any case, I will take your advice and resurface the flywheel when I replace the clutch.
Old Nov 29, 2015 | 10:25 AM
ve69tte's Avatar
ve69tte
That is exactly what it does. I guess a broken spring would create uneven pressure making the assembly bind while it is moving along the shaft.
Any suggestions as to where I should buy the new clutch? Should I order AC Delco from the local parts store or are these on-line stores OK?
Old Nov 29, 2015 | 06:39 PM
Kim72's Avatar
Kim72
I'm running Centerforce myself. No complaints with it. Only cruise with mine (no racing). I'm sure lots of others have their personal preferences. I guess anywhere you can get the best price will work. Summit and Jegs are good.
And yes, I would have the flywheel resurfaced to remove any hotspots you might have in it. You don't want to do the job twice!! That's always a bummer.
Old Apr 30, 2023 | 02:18 AM
BK N 66's Avatar
BK N 66
[QUOTE=Kim72;1591004185]I'm running Centerforce myself. No complaints with it. Only cruise with mine (no racing). I'm sure lots of others have their personal preferences. I guess anywhere you can get the best price will work. Summit and Jegs are good.
And yes, I would have the flywheel resurfaced to remove any hotspots you might have in it. You don't want to do the job twice!! That's always a bummer.[/QUOTE
Old Apr 30, 2023 | 02:41 AM
Mark_UK's Avatar
Mark_UK
I've never had this problem on a Corvette but you might want to check the rubber block on the transmission mount of the front nose cone, if this has degraded and there is even slight play up there the car will shudder badly when setting off from a stop.
Old Apr 30, 2023 | 07:53 AM
HeadsU.P.'s Avatar
HeadsU.P.
People complain that their Internet Service is slow, but 7 years for your posts to show up?
To Strange clutch behavior
