Frame question...1973 Coupe
Old Dec 3, 2015 | 08:57 AM
tncop2361's Avatar
tncop2361
Default Frame question...1973 Coupe
Is there a way to check a bare frame for straightness or is it best to take it to a shop? I have the frame stripped and want to verify there are no issues with it before having it powdercoated.
Old Dec 3, 2015 | 10:02 AM
diehrd's Avatar
diehrd
There are measurements you can make from a level surface . I forget where I have seen the diagrams , try the search function
Old Dec 3, 2015 | 10:04 AM
Peterbuilt's Avatar
Peterbuilt
The diagrams are in the 73 GM service manual.
Old Dec 3, 2015 | 11:26 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by tncop2361
...want to verify there are no issues with it before having it powdercoated...
Is there any reason to believe it isn't straight? Any indication of possible damage before you removed it?
Old Dec 3, 2015 | 01:19 PM
tncop2361's Avatar
tncop2361
Yes there is a small indentation in a frame rail where something struck in...maybe 1/8-1/4" in depth and about 18" in width
Old Dec 4, 2015 | 10:24 AM
Bills17n72's Avatar
Bills17n72
if it was me ,and if you are gonna use that frame ,I would have a qualified person check it out ,might save you problems down the road!!!
Old Dec 4, 2015 | 02:00 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
With all the unibody cars theres not as many "frame" shops but even uni-bodies get rebent after accidents and many body shops will have there own frame straightening rig. Plenty of pick ups, suburbans and explorers out there to. Just ask around the local body shops. If one doesnt have one then call another body shop. Now with the body off it could/can be done at home but it will take some learning and improvising with come-alongs and maybe hydraulic jacks. No i havent done this but for small corrections while the frame is stripped it should be possible.
Now if u have the frame stripped then this is the time to do upgrades to the frame. The Chevy Power Manual has all the locations to reinforce and strengthen the C3 frame. And theres not really that much but if plan to do any circuit track type racing u will wish u had this. Look up posts by Bee-Jay for his front end failure while racing.
Hope this helps.
To Frame question...1973 Coupe
