Interesting Discovery
Old Dec 6, 2015 | 05:46 PM
SwampeastMike's Avatar
SwampeastMike
Default Interesting Discovery
My '79 L82 is up on high jack stands for the winter as I do a lot of cleaning and (mainly) preventative maintenance.
I've only had it about a year as the spouse presented it to me for a birthday present as a car built the year I turned 16. It was very nicely running, licensed and insured but in need of a lot of work--mainly electrical.
The engine seems completely stock down to the emission controls. I was surprised to find such in my area of the country which has always had quite lax emission control enforcement and requirements. Stock exhaust manifolds and I even verified that the A.I.R. pump is functioning.
Performance always surprised me as being very good for an emission controlled car of that era--it made me wonder why.
Why?
No catalytic converter and true dual exhaust with 2 1/2" (minimum) o.d. pipes all the way back from their connection to the exhaust manifold! I'm almost ashamed to admit that I never noticed it wasn't installed. Needless to say the A.I.R. pump belt is now removed
Old Dec 6, 2015 | 06:29 PM
toobroketoretire's Avatar
toobroketoretire
The catalytic converters used on the '79's were very high flowing and didn't reduce the power at all UNLESS they got plugged with carbon because of an oil burning engine. When they fail chunks of their core break out which makes them flow even more.
Old Dec 6, 2015 | 06:39 PM
GUSTO14's Avatar
GUSTO14
Mike, back in 1977 myself and a couple of friends all bought similarly equipped, new Corvettes. They of course came equipped with the early "pancake" style converters. All of our cars would top out at about 125 within a couple of MPH of each other. A few years later we were all lamenting how much power we were losing as a result of the converters and how we really should do something about it.
One friend decided he would change over to the C3 side pipes offered in '69 and I decided to install a "test-pipe" in place of my converter to see for ourselves what difference it made. With the stock original exhaust manifolds (2" outlets), both of our cars would then hit 130. Not sure how much horsepower that equated to, but it was definitely noticeable.
I don't believe that you would see that much of a gain today with the monolith converters most vehicles come equipped with today however.
Good luck... GUSTO
Old Dec 6, 2015 | 06:59 PM
GUSTO14's Avatar
GUSTO14
Steve, I may be wrong, but I believe that the '79's were still equipped with the flat "pancake" style converters like those that came on my '77.
These converters were filled with pellets that were not nearly as free flowing as the later monolith's. I recall back the early 80's that by then many of them would "clog" and become restrictive. Typically between about 75k and 100k miles. I believe the Monoliths, sometimes referred to as hi-flowing converters didn't get introduced until about 1981.
Good luck... GUSTO
Old Dec 6, 2015 | 07:15 PM
SwampeastMike
That's pretty much what I thought. BUT...
Please explain to this ignoramus why a great many people in the day and until this day insist that "opening" the exhaust will result in significant performance improvement from an engine designed for maximum performance that also complies with government regulations.
Old Dec 6, 2015 | 10:19 PM
74modified's Avatar
74modified
I will explain - the "pan cake" style cat was developed using existing refinery catalyst technology. The platinum loaded alumina sol based spheres were fine as a catalyst, but did not hold up as well in an automotive use. The exhaust flow had to travel through the void space between the beads. It was not the best flowing equipment when new. As beads broke down, the fines would migrate to the voids and cause restriction. The engine controls (tuning) at the time were not near what we have now, and a bad tune could carbon the cat. If leaded gas was used (pretty common in the mid to late seventies), the catalyst was poisoned, and carbon would plug the voids, as would happen with an oil burner. The later "honeycomb" extruded catalysts are much better flowing, and tend to last longer.
Old Dec 6, 2015 | 10:28 PM
7t9l82's Avatar
7t9l82
The 79 cats were as useful as a stopped up sewer and flowed about the same.
Old Dec 7, 2015 | 01:30 PM
gungatim's Avatar
gungatim
no scientific basis whatsoever for what I am about to say, but, I grew up with all GM RWD vehicles. every one I and my friends had, eventually the exhaust rotted off after the cat. we would drive them with just the cat. they were louder, but nowhere near as loud as with no cat. they also had a noticeable seat of the pants power increase.
my feeling was that the muffler restricted the exhaust flow more than the cat did. while the cat did restrict more than just straight pipe, it probably didn't rob any real power, it was the mufflers that did...especially the really quiet ones on stock cutlass/caprice/monte carlo's, etc...
just my observation and recollection from the 70's/80's...taking off the cat but leaving the stock exhaust/mufflers probably did nothing for performance...
Old Dec 7, 2015 | 04:10 PM
pauldana's Avatar
pauldana
Remove the the cat, put on a true duel exhaust with a X-pipe, headers, and some good mufflers like Borla, and you WILL feel the difference from bottom RPM to the top, and it shows in the Dyno very well... .. BEST #1 MOD FOR A C3 CORVETTE...
Old Dec 7, 2015 | 04:30 PM
454Luvr's Avatar
454Luvr
Early '70s factory dual exhaust was very free flowing. It was one of the best you could buy at the time and much superior to glasspacks. If that's what's in this '79, the PO did you a favor.
Old Dec 7, 2015 | 04:31 PM
SwampeastMike
I'm pretty much pleased with the performance as is even if I'm no longer as confident about what is and isn't stock. It does have true dual exhaust but with the stock exhaust manifolds. The mufflers have definitely been replaced and have a great sound. I see "HOG" and "1068" (two different lines) in raised lettering on the top of the mufflers.
Old Dec 7, 2015 | 04:45 PM
pauldana's Avatar
pauldana
True duel exhaust does NOT "Y" into catalitic converter and then out... True duel starts from the exhaust manifolds and end in the back... The ONLY linkng between the 2 would be a "H" or "X" pipe..
If you are running through a single cat, you do NOT have true duel exhaust.
Re-read your first post... Sorry... Sounds like you do not have the Y to the cat... Yes... Made a differance when I first removed mine many years ago also...
Old Dec 7, 2015 | 05:23 PM
SwampeastMike
Sorry if I wasn't clear. My surprise is that there is NO catalytic converter and that I have TRUE dual exhaust from the stock manifolds through to the mufflers.
What threw me off was that the A.I.R. pump was installed, connected and functioning. I verified its' operation. I'd never really looked for the cat as I assumed it had to be there.
Old Dec 7, 2015 | 06:21 PM
454Luvr's Avatar
454Luvr
Back when I had my '72, inspection stations would pop the hood and check to be sure all the basic equipment was there. You couldn't just remove the air pump. There was a rumor that you could open the pump, break out the internal plastic vanes and reinstall it, with no one the wiser.
Old Dec 7, 2015 | 06:49 PM
Magna_Flow's Avatar
0Magna_Flow
Former Vendor
This is true. Early catalytic converters were less than ideal in pretty much every regard. Modern cats are incredibly high-flowing and work extremely well in cleaning up emissions. Most of the damage we see to catalytic converters today comes from bad tunes or severely worn engines. A modern monolithic cat should easily last well over 100,000 miles.
Old Dec 8, 2015 | 08:19 AM
biackbenz's Avatar
biackbenz
Why?
Hey Mike,
Why remove the AIR Pump?
Old Dec 8, 2015 | 06:00 PM
SwampeastMike
Originally Posted by biackbenz
Hey Mike,
I have not removed the A.I.R. pump, but I did remove the belt that operates it. Why?
A.I.R. stands for "Air Injection Reaction" with that reaction occurring in the catalytic converter. With no catalytic converter there is absolutely zero reason for that pump to be running as there is no place for the required chemical reactions that reduce noxious emissions to occur!
To Interesting Discovery
Old Dec 8, 2015 | 07:53 PM
mikem350's Avatar
mikem350
[QUOTE=SwampeastMike; With no catalytic converter there is absolutely zero reason for that pump to be running as there is no place for the required chemical reactions that reduce noxious emissions to occur![/QUOTE]
Not exactly true, some pre cat cars have AIR pumps also. Some further combustion does take place in the exhaust piping.
I would save EVERYTHING you take off the car for posterity.
BTW, if you look up the special components of the L82 you will be pleased!
Old Dec 8, 2015 | 07:54 PM
pauldana's Avatar
pauldana
The tubes that go into the manifold that inject those gases cause a restriction in the flow taking them out will also add a little bit more horse power because a better flow
Old Dec 8, 2015 | 09:19 PM
454Luvr's Avatar
454Luvr
That's not correct. The pump injects air into the exhaust manifolds through small tubes located near each exhaust valve. The purpose is to promote a more complete combustion of exhaust gasses. It is not connected in any way to the catalytic converter. Disconnecting the pump is primarily of benefit in eliminating the horsepower consumed by the pump itself. I also seem to remember that the exhaust manifolds will operate at a lower temperature without the secondary combustion.
