Horn Assembly 1978
Old Dec 13, 2015 | 09:52 AM
Indian-giver's Avatar
Indian-giver
Default Horn Assembly 1978
Anyone have a diagram of the steering wheel horn assembly. My recently purchased C3s horn does not work. Upon removing the horn cover I see several parts missing.
Old Dec 13, 2015 | 12:19 PM
G-Sting's Avatar
G-Sting
Here's a steering column diagram from a '79. Any help? (An AIM is a really nice thing to have.)
Old Dec 13, 2015 | 06:44 PM
DUB's Avatar
DUB
When you are messing around with this...MAKE SURE that (SPACER 9A) is INSTALLED AS IT IS SHOWN IN THE DIAGRAM.....VERY IMPORTANT!!!!!!!!!!!!!!!! IT MAKES DIFFERENCE.....even though it can be flipped....if you do flip it...you can break it when using your telescoping feature.
DUB
Old Dec 13, 2015 | 09:25 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Use this diagram, it'll find your problem
-Willcox
Old Dec 14, 2015 | 08:38 AM
Indian-giver
Thank you for the informaton. I found the retainer and the pin laying in the hub. Reasembled it and works fine. PO must have removed the wheel for some reason.
To Horn Assembly 1978
