okay what happened here?...
I warmed it up and pulled out the driveway and went about a mile down the road and it suddenly made two VERY loud backfires, and died, and I coasted to the side of the road. I couldn't tell if they were on the intake side or exhaust side but they really scared the crap out of me. I popped the hood, pulled the shielding cover off the distributor and checked for loose plug wires or anything else obvious, since I did have a brief problem with the shielded plug wire shorting out intermittently on the + terminal of the coil, which was fixed by just shoving the shielding down a little with my finger. I thought maybe it had shifted back but it hadn't. I jumped back in and the car fired right up and I just drove it strait home and put it away since I had a family dinner to attend and didn't have time to mess with it.
I came home tonight after work and took a better look. It fired it right up. It ran fine and idled in my driveway for about 30 minutes with me looking things over and trying to make it happen again so I could see what had occurred. Nothing... car runs fine and fired right up each time I shut it off. Went up and down the driveway, no problem (long driveway). Didn't take it down the road though since it was getting late and I didn't feel like getting stranded in the dark. This is a 400hp L-68 tri-power car, with the original carbs that seem to be functioning fine except maybe for leaky floats causing me to crank the hell out of it to start it after sitting for a while since the bowls drain.
I can't figure out what the heck happened and being completely OCD, I'm now afraid to drive the car until I can positively identify what occurred. I know a lot of guys would just brush it off as a fluke thing but it's really bugging me. Anybody got any thoughts on what might have happened? I can't make it happen again for the life of me...
thx
I ASSUME the engine was rebuilt???
During this 'warm-up' before you took it for drive when it backfired..was it idling very good?
How fast were you going approximately when the backfire occurred???
Were you coming off a higher RPM run when it occurred???
I 100% agree with 'AW IR C3'...because depending on the type of gear on the distributor...which can be influenced by the camshaft used and what the cam manufacturer want for a distributor gear...they can wear. NOT wanting to make you PARANOID....but you only turn over about four pieces of the Jeopardy puzzle. So a precise diagnosis is REALLY HARD to do.
With it cranking back up and not doing it since....it is hard to 'say' due to not knowing if the backfire came out of the exhaust or carbs.
DUB
thx
It does sound like your ignition coil got shorted out because when that happens the cylinders pump a LOT of fuel and air into the HOT exhaust system.. When the coil becomes un-shorted the mixture in the exhaust system will go KA-BOOM and that's probably what you heard. I would check your shielding again to make darned sure its not touching your coil in any way.
I think I'm going to stop running the car and pull the distributor over my pending two week xmas vacation to get a better look at the gear, as well as the cam gear. With the distributor out I can shine down there with a flashlight and turn it over to see every tooth and know where to go from there.
Thx
I wouldn't suspect power valve necessarily; typically you get permanent drive-ability issues when they blow. They also tend not to be the cause of a backfire, rather are the result of a backfire.
I think you'll find the cause in the ignition system somewhere. If its from the aforementioned coil situation, bad gear, inductive pickup having moisture or the rotor having rust, etc.
Good luck looking. Keep us updated on what you find.
Also good idea on the boroscope, especially since they seem to have become very affordable these days. You can get them for $20 that plug into the USB port on your laptop. I've got one coming.
I agree the power valve might have been caused to be bad by the backfire, but it runs fine so I don't think it was.
I think it may be jumping the gun assuming it's the cam gear. Start with the easiest stuff first. Save yourself some money. If you look hard enough you'll find a crappy connection somewhere. Could just be a ground.
Also could it be that my coil is damaged from when it was being shorted from the positive terminal to that ignition shielding? Is there any way to test the coil?
Thx
Yep, I split a muffler wide open years ago. Back in the 1950's it was fun to turn the key off and let the car coast for about 50 yards then turn the key back on and........................KA-BOOM. If your coil still produces a spark its okay.
it sounds like ignition cut out to me. if you've ever turned the key off and back on really quickly, that is exactly what happens. could be switch, could likely be the wire that had the shield grounding issue.
It was my transistor ignition, the pickup coil in the dist. failed.
After a flat deck trailer home, it started right up and ran fine. Credit to Dave Fiedler for diagnosis, he said most of the pickups fail this way.
Maybe my recollection is off but I thought the end carbs lacked idle circuits. This drives my previous comment vs the idea that they would just mess up the idle.
I doubt that you distributor gear needs inspection...but do as you wish.
I agree that it is a connection somewhere that is loose or needing repair.
AS stated above.....start simple...because chances are that it is going to be something simple.
DUB
Based on that assumption, would it be possible to pop the tumbler assembly out and spray contact cleaner into the switch, then cycle it a couple dozen times to clean it up? I'm not sure how the switch is constructed or if the contact cleaner would get to the right part of the switch, does anyone have one out they could look at?
Alternately, NOS ignition switches are plentiful on ebay- although not exactly cheap... so if it comes down to it I'd be happy to pull the trigger on one for peace of mind.
