Odd Solid Roller Valve Lash Observation While Adjusting
Old Dec 16, 2015 | 03:15 AM
centuryoldracer's Avatar
centuryoldracer
Originally Posted by gkull
What are you running that requires 1200 pounds open pressure? That is a little far removed from a small block with 5/16th push rods and maybe 600 pounds open. I use the CC high tech .105 wall
I've just never experienced a lash change after setting and then rotating the motor
ProStock
