Speed-O Cable Trans Seal
Old Aug 29, 2002 | 08:50 AM
Edzred72's Avatar
Edzred72
Default Speed-O Cable Trans Seal
(WENDS) What a beautiful evening in nothern Illinois..think I'll go for a spin. AWWWWW...trans fluid all over the garage floor :mad :mad
Looks like the speed-o cable trans seal is shot. How does this come out so I can change the O ring? In my AIM manual, I noticed two screw clamps holding the unit in. Is that all there is to it??? Also, is this seal (AUTO TRANS) available from local parts stores?
Thank You Guys
Eddie
Old Aug 29, 2002 | 09:19 AM
Pete79L82's Avatar
Pete79L82
Default Re: Speed-O Cable Trans Seal (Silvr77)
Just remove the clamp and pull out the gear adaptor. Some fluid will come out.
There are 2 seals. An o-ring that goes around the outside of the adaptor and a small lip seal that goes on the inside of the adaptor against the speedo gear. Not sure if the parts house has them but they are inexpensive at a GM dealer.
Old Aug 29, 2002 | 12:44 PM
Edzred72's Avatar
Edzred72
Default Re: Speed-O Cable Trans Seal (Pete79L82)
Thanks Pete. I just got off the phone with AutoZone and they carry both!
Lucky me....
Eddie
To Speed-O Cable Trans Seal
