383 build advise
Old Dec 31, 2015 | 11:36 PM
nivensid's Avatar
nivensid
Default Blueprint 48002-k cylinder heads
Based on my previous post would these heads work well with my build? For the time being I will have to stay with the 350 auto trans and 3.08 rear gear. I know this would help on the low end but I have to do this in steps. Thanks everyone...
Brand:
BluePrint Engines
Manufacturer's Part Number:
H8002K
Part Type:
Cylinder Heads
Product Line:
BluePrint Engines Muscle Series Cylinder Heads
Summit Racing Part Number:
MLL-H8002K
Cylinder Head Style:
Assembled
Cylinder Head Material:
Aluminum
Cylinder Head Finish:
Natural
Combustion Chamber Volume (cc):
64
CNC-Machined Combustion Chamber:
No
Intake Runner Volume (cc):
195cc
Exhaust Runner Volume (cc):
75cc
CNC-Machined Intake Runner:
No
CNC-Machined Exhaust Runner:
No
Intake Port Shape:
Rectangular
Intake Port Location:
Standard
Exhaust Port Shape:
Square
Exhaust Port Location:
Standard
Spark Plug Style:
Straight
Intake Valves Included:
Yes
Intake Valve Diameter (in):
2.020 in.
Exhaust Valves Included:
Yes
Exhaust Valve Diameter (in):
1.600 in.
Valve Springs Included:
Yes
Maximum Valve Lift (in):
0.575 in.
Outside Diameter of Outer Spring (in):
1.437 in.
Damper Spring Included:
Yes
Number of Springs Per Valve:
Dual
Retainers Included:
Yes
Retainer Material:
Chromoly steel
Locks Included:
Yes
Lock Style:
7 degree
Valve Stem Seals Included:
Yes
Rocker Arm Studs Included:
Yes
Rocker Arm Nut Thread Size:
3/8-24 in.
Rocker Arms Included:
No
Rocker Arm Nuts Included:
No
Guideplates Included:
Yes
Valve Cover Mounting Style:
Perimeter bolt
Accessory Bolt Holes Drilled:
Yes
Valve Guides Included:
Yes
Valve Guide Material:
Manganese bronze
Valve Seats Machined:
Yes
Valve Seat Machine Style:
3-angle
Valve Seat Material:
Chrome nickel
Steam Holes Drilled:
No
Oiling Style:
Through pushrod
Machined for O-Ring:
No
Heat Crossover:
No
Old Jan 1, 2016 | 02:57 PM
96 lt-4's Avatar
96 lt-4
They should make good power however it will still be soft on the bottom end with 3.08 gears and a low stall converter I would guess.Get as much initial timing advance as you can to help out with the low end.
Once you get some gears down the road I would try a slightly larger carb as I bet that combination would make more power with a good 650/700/750 vacuum secondary Holley.
Old Jan 1, 2016 | 03:37 PM
nivensid's Avatar
nivensid
Thanks 96 lt-4, I will continue looking for better suited heads for this build to help out on the low end. I do plan to go with a 2400 stall which should help out if I do go with these heads until I can swing the gears and 200R4 trans.
Old Jan 6, 2016 | 11:33 AM
BluePrint Engines's Avatar
0BluePrint Engines
Former Vendor
Brand:
BluePrint Engines
H8002K
Part Type:
Cylinder Heads
Product Line:
MLL-H8002K
Assembled
Aluminum
Natural
64
No
195cc
75cc
No
No
Intake Port Shape:
Rectangular
Standard
Exhaust Port Shape:
Square
Standard
Spark Plug Style:
Straight
Yes
2.020 in.
Yes
1.600 in.
Yes
0.575 in.
1.437 in.
Yes
Dual
Retainers Included:
Yes
Retainer Material:
Chromoly steel
Locks Included:
Yes
Lock Style:
7 degree
Yes
Yes
3/8-24 in.
No
No
Yes
Perimeter bolt
Yes
Yes
Manganese bronze
Yes
3-angle
Chrome nickel
No
Oiling Style:
Through pushrod
No
Heat Crossover:
No
Hi Nivensid
We saw your post and wanted to thank you for your interest in BluePrint Engine’s 195cc Muscle Series aluminum cylinder heads.
We use these heads with a camshaft very similar to the grind you talked about with great low to mid-range torque producing close to 400 hp and 400+ torque in a 355.
What LT-4 mentioned about being lazy on the bottom has nothing to do with your engine combo, but your rear differential gearing. The 3.08’s are more of a highway gear, but with your 355 and our heads, you will have a vast improvement over the stock 350, nearly double the power and torque. Like you said, going to a steeper gear and an overdrive transmission in the future will make your Corvette even more fun; but I doubt you will be disappointed in the performance in the meantime.
Feel free to contact us with any questions you may have on any of our products.
Scott Liggett
BluePrint Engines
1(800)483-4263
info@blueprintengines.com
www.blueprintengines.com
Old Jan 6, 2016 | 11:52 AM
Luce's Avatar
Luce
Hey Scott. Good to see you guys have a presence on the web. I'm filling in the blanks on one of you're long blocks. I hope to be able to sing your praises soon.
Old Jan 6, 2016 | 09:51 PM
68post's Avatar
68post
With; your cubes , small 625 carb, 2,400 stall, small cam, and performer intake , along with the Blueprint heads - I think you'll have plenty of torque "off idle" . Enough to light-up a set of street tires . If not then some tuning is required.
Your mid-range torque is going to kick in just above your stall also ... and away we go..
( with the gear change - also change to an RPM intake with a bigger better carb)
$.02
Old Dec 5, 2016 | 04:30 PM
NewbVetteGuy's Avatar
NewbVetteGuy
Here's one more idea: Instead of a 200r4 swap; do a 700r4 swap and take advantage of the low 1st gear to help get you accelerating and make up for your 308 rear gears. You could also go with a 2800 lockup stall which would again, help you on the low end to get going AND you'd have ridiculously awesome highway cruising fuel economy with the 3.08 and .70 OD on the 700r4.
Right now you've got a torque multiplication ratio of 3.08 x 2.52 = 7.76 ratio; the 200r4 has a 2.74 1st gear so 3.08 x 2.74= 8.44 ratio ; the 700r4 has a 1st gear of 3.06 so 3.08 x 3.06 = 9.42 ratio. -That's much better and combine that with a good stall and some good budget heads like the Blueprint combined with your smallish cam and you should have plenty of actual torque at the wheels to get it moving AND you'll get stupid good highway MPG if it doesn't bog.
A 700r4 swap will cost more than a 200r4 swap (but less than a 200r4 + new rear gears) as you'll need a new cross member and you'll need your drive shaft cut, welded and balanced (I got mine done for $75); but you can get some good acceleration and not have to deal with the rear end gears and keep that cruise RPM low and highway mpg high.
Adam
Old Dec 5, 2016 | 04:41 PM
NewbVetteGuy
And while I doubt you'll find better flowing heads than the BluePrint H8002k for $895 a pair, it's currently worth looking at the Jegs-stamped Profiler 195cc heads for $998 a pair:
http://www.jegs.com/i/JEGS-Performan...14022/10002/-1
BluePrint H8002k
CFM Port Flow Average @ 28"
.100" - 83
.200" - 150
.300" - 190
.400" - 223
.500" - 252
.600" - 245
Jegs/ Profiler 195cc
Lift Intake CFM Exh CFM % Exh/Int
0.200 145 110
0.300 209 145
0.400 254 180
0.500 273 206
0.600 274 213
0.700 276 216
0.800 276 218
When the current sale ends the BluePrint heads will be significantly cheaper, but right now, IMO the extra $100 gets you quite a bit of flow.. (21 CFM @ 0.500" could be 42 hp for $100 ($2.38 per HP))
Adam
