Borgeson Power Steering Box Question
Old Dec 27, 2015 | 01:29 PM
Ranger24's Avatar
Ranger24
Default Borgeson Power Steering Box Question
I'm converting my PS plumbing to AN. As I removed the current plumbing (inverted flare plumbing that came with the kit) I've run into an issue with the return side brass compression fitting that sits inside the hole...it won't budge. Has anyone removed this and if so is there a trick to it?
Old Dec 27, 2015 | 05:06 PM
Street Rat's Avatar
Street Rat
I'd try an easy out. Tap it in the hole and see if you can dislodge it by turning counter clockwise on the easy out.
Old Dec 27, 2015 | 08:19 PM
Ranger24's Avatar
Ranger24
Thanks Rat, I'll give it a try.
Old Dec 28, 2015 | 12:37 PM
Denpo's Avatar
Denpo
I'd put something in the hole before tapping, like a little piece of cloth to avoid shaving to get in.
I was faced with a similar problem.
Old Dec 31, 2015 | 03:48 PM
Ranger24's Avatar
Ranger24
Ya, I wondered about that part of it. I solved this by buying one of their universal inverted flare fittings rather than struggle with trying to remove the brass.
To Borgeson Power Steering Box Question
