Six speed / 2.87 gear
Old Jan 4, 2016 | 05:45 PM
forvicjr's Avatar
forvicjr
1st would just blow the tires off. At a hard start starting in second was more affective with the five speed. I dont want the same with this six speed install.
Old Jan 4, 2016 | 05:50 PM
gkull's Avatar
gkull
i did a lot of calculations with over drive trannies. 4.11 for over 20 years in my Vette. You just figure out top gear and the rest just fall where they are. I really believe that 3.90 is about ideal when you have .70 .64, and .62 OD ratios
As my power went up so did my tire width. I also tried to attain 40% front and 60% rear weight. The rear differential has to attached so it can't move. You have to replace or mod the rubber mounted diff cross member. You have to run big rear spring weights to put the power to the ground.
Old Jan 4, 2016 | 06:33 PM
forvicjr's Avatar
forvicjr
40/60 front rear prob wont happen with an iron headed big block for power.
Old Jan 6, 2016 | 09:47 PM
tixeon's Avatar
tixeon
Originally Posted by forvicjr
215 75 15. These tires are somewhat temporary. Plans are 315 30 18 on a 18x10.5 on all four corners. These would be 25.4 inches tall.
What all will you have to modify to pull this off?
Old Jan 7, 2016 | 08:59 AM
forvicjr's Avatar
forvicjr
From what Ive read these will tuck with no flares with little tire rub.
Search "18x10 295/35 all four corners"
Old Jan 7, 2016 | 09:19 AM
bashcraft's Avatar
bashcraft
These tires are going to look horrible. They're way to short.
Old Jan 7, 2016 | 11:50 AM
forvicjr's Avatar
forvicjr
I will be lowering the car. the 18s are comparable to a 245 60 15 which I have had on the car.
Old Jan 8, 2016 | 09:21 PM
Gale Banks 80''s Avatar
Gale Banks 80'
245 60 15 is 26.6 diameter or very close to the 27" diameter C3's left the factory with. Not 25.4 ". Its going to look like it has go kart tires on it.
Old Jan 9, 2016 | 04:43 PM
BLUE1972's Avatar
BLUE1972
The dimension's for a F70-15 tire is listed as:
F70-15 6.00 rim 8.35 with 26.92 height
My original Firestone spare is :26.50" high =
Old Jan 9, 2016 | 06:31 PM
forvicjr's Avatar
forvicjr
Ok guys, 315 30 18s on 10.5 wheels. No go cart look here.
