Kris_K
close
- Member SinceOct 2011
- LocationKilleen, Texas
Liked:23 Times in 18 Posts
Has anyone tried this intake on a 68-72 BBC? It lists the carb pad height at 4.45". That is less than an inch more than the 3.57" stock manifold. Any chance this manifold fit with a drop base filter?
Also, it's made for a square bore carb. Any recommendations for a good low profile square bore carb for a 70 454 with Edelbrock heads?
Kris_K
close
No, this one: http://m.summitracing.com/parts/nal-...make/chevrolet
ddawson
close
- Member SinceMar 2001
- LocationLincoln, CA
Liked:644 Times in 519 Posts
I don't see that fitting.
Clay your current setup and see how much room you have.
I have the repro LS6 manifold with the OEM heatshield and 3/8 wood spacer.
I have about 3/4" clearance. I tried a 1/2 spacer on the top of the carb and it fit but after driving around the engine movement caused it to rub on the hood.
Here is how it looks.
rklessdriver
close
- Member SinceApr 2005
- LocationDale City VA
Liked:431 Times in 280 Posts
That's a re-badged Edelbrock Performer RPM 7161. I don't know what accounts for the 4.450 carb pad height on the GM because the Edelbrock says 5.220.... I think that the GM measurement is jut plain wrong as Edelbrock cast and machines almost all of the GMPP intakes and cyl heads.
FYI - People have used the Performer 2-0 2161 which is 4.850 with a deep dropped base air cleaner.
Will
Will
Kris_K
close
Thanks, what kind and size of air cleaner are you using? Also what's the purpose of the wood spacer?Originally Posted by ddawson
I don't see that fitting.Clay your current setup and see how much room you have.
Quote:
Insulates the carb from the intake. Reduces heat related performance issues. But.....Ive always used pheonolic (sp) resin spacers, which look like a cross between plywood and bakelite. Is this the same thing as the 'wood spacer'?Originally Posted by Kris_K
Exploreddawson
close
Sounds about right
Mine looks like this but is 4 hole.
http://www.summitracing.com/parts/sum-g1405/overview/
