1969 Ignition (Keyswitch) problem
Old Jan 4, 2016 | 11:54 AM
Troy F's Avatar
Troy F
Cruising
Default 1969 Ignition (Keyswitch) problem
I recently inherited a 1969 coupe (manual), she has "issues", but nothing that a little work and a LOT of money won't solve.
The first problem I have is that my Father-in-Law (from whom I got the car) has lost the keys.
He went and got a new key lock cylinder, but we cant get the old one out... I have the steering wheel off, but I can't seem to find the little unlocking tab with my screwdriver.
Any tips or suggestions would be greatly appreciated!
Old Jan 4, 2016 | 12:36 PM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
You have to remove the lock plate and the turn signal switch
Old Jan 4, 2016 | 12:38 PM
Troy F's Avatar
Troy F
Cruising
I've actually got those off as well... after that, I'm lost
Old Jan 4, 2016 | 03:30 PM
toobroketoretire's Avatar
toobroketoretire
Default Removing Lock Cylinders
Google "Removing 1960/1970/1980 Chevrolet Key Lock Cylinders" for detailed instructions.
Old Jan 4, 2016 | 05:15 PM
Troy F's Avatar
Troy F
Cruising
EVERYTHING I find tells me I have to have the key... I don't.
Old Jan 4, 2016 | 09:30 PM
GAVelle's Avatar
GAVelle
You don't need the key. Stick a long skinny screwdriver toward the lock where the release tab on the lock should be. You can't see the release tab because of a very thin flash metal membrane that is part of column/housing. This membrane results from the manufacturing process. You have to pierce through this membrane to reach the release tab. When you do this and press in the tab with the screwdriver you should be able to remove the lock from the column. I had to do this same procedure last year on a 1971, and found the solution I just gave on this forum. After you get the lock out, you will find a number on the lock that a locksmith can use to create a key that works. Or, you can buy a replacement lock cylinder that already has keys. I had keys made for the original, and it all works perfectly.
Old Jan 5, 2016 | 07:43 AM
Jim Shea's Avatar
Jim Shea
It is very important that you indicate if you have a standard (non-adjustable) steering column or a tilt & telescoping type. They both use the same lack cylinder but the die cast lock housing is a bit different.
You didn't mention the type but since you have a 1969 Vette, it is most likely a standard type column since T&T columns were fairly rare back then.
Here is a pic of the standard lock cylinder with a thin bladed screwdriver indicating the location of the slot in the housing where you can depress the lock cylinder tab.
If you have a T&T column, I can find another pic of that type.
Jim
Old Jan 5, 2016 | 04:10 PM
Troy F's Avatar
Troy F
Cruising
Worked like a charm!! Thank you!!
To 1969 Ignition (Keyswitch) problem
