Turn signal question
Old Jan 8, 2016 | 09:21 AM
nivensid's Avatar
nivensid
Default Turn signal question
Replaced the front turn signal pigtails with new ones from Zip Corvette. Now without the headlights on the turn signals work. When I turn on the headlights none of the signals work and both indicator lights are illuminated in the dash panel. Turn off headlights and signals work again. 78 vette. Any ideas?
Old Jan 8, 2016 | 09:47 AM
Redhook98's Avatar
Redhook98
Bad ground. Same happened to me. The other filament is being used as a ground. You wired them incorrectly, or they are not grounded properly.
Old Jan 8, 2016 | 10:42 AM
nivensid's Avatar
nivensid
Thanks, don't know how could have wired incorrect, its plug and play. Thanks again. Will have to check grounds
Old Jan 8, 2016 | 11:35 AM
mikem350's Avatar
mikem350
You could change back to the original pigtails, see if all is well.
But I vote for bad grounding first!
Old Jan 8, 2016 | 11:24 PM
454Luvr's Avatar
454Luvr
Coincidentally, I've just discovered the '82 I bought last month has a similar problem. Been working on other issues, took her for a night drive this evening for the first time. Turn sigs don't work when the lights are on. Will appreciate knowing what you find.
Old Jan 9, 2016 | 08:26 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The issue you describe is common to a ground issue. If this just started with the installation of the new jumper extensions then the connector on your main harness you plugged them into may be corroded or the terminals may be bent.
I'd go there first and check them, possibly some dielectric grease would help you too.
-Willcox
Old Jan 15, 2016 | 11:11 PM
454Luvr's Avatar
454Luvr
Well, I spent most of the afternoon working on this, and the problem is fixed. I basically replaced and greased all the 1156 and 1157 bulbs in the front, side and rear. Some dufus had tightened down all the rear lamp housings without centering the plastic rods in the holes in the body. Couldn't figure out why I had so much trouble getting the lamp holders in and out. One of the holders has a crack because of this and won't twist back in, so I'll have to replace it with a pigtail. Anyway, when I was done with all this, the signals were working with the headlights on or off. The last problem I had was they were flashing way too fast. The "on" condition was just a brief blip that could hardly be seen. That turned out to be the flasher itself. Incidentally, the owner's manual for my year ('82) says the fuse holder is behind the glove box. I almost removed the box searching for the flasher, but then decided to check online. Turned out it was under the driver's dash above the kick panel, just like my early-'70s C3s. That's strike two for this manual...
Good luck with your problem, hope the fix is as easy as mine!
To Turn signal question
