LED dash lights
Old Apr 25, 2020 | 08:32 AM
Popeye206's Avatar
Popeye206
I just replaced the dash lights of my 1978 Pace Car with LEDs. I used the equivalent to a 194 bulb. I bought them from Ebay with the removable sockets.
I wanted to share a few things that might be useful to others.
1. This is a good 3-4 hour job to do the main dash and center gauge lights.
2. You must remove seats, and side panels to remove the center dash and get at the lights.
3. You must remove the side vent duct and loosen the steering wheel to remove the main gauge cluster. However I did not remove the steeringwheel. I spent a lot of time and brain power trying to avoid some of this, but in the end, it was necessary and NOT ALL THAT BAD in the end to do.
4. CAUTION! The plastic pieces in and on your dash may be brittle and tightening screws too much may break the piece you're putting on. ALWAYS tighten screws by hand... no power tools!
5. TEST, TEST, TEST! BEFORE you reassemble! Make sure you test the cluster while you have it out of the dash! You may need to turn the bulb 90 degrees in the socket to get the right polarity for it to light. Or in one case, I needed to use a different socket as the original one was worn and not making good contact. Either way test EVERY bulb you can before putting the cluster back in or you will be sorry!
In the end... the bulbs cost me about $30 and I used blue for the gauges (14 of them total) and white for indicators. The end result is very cool and the dash is much brighter!
A cost effective, yet time consuming project, but well worth it! Enjoy!
Old Aug 15, 2023 | 09:26 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
I did my LED's twice. First time I used blue. Looked very cool but the instruments were almost unreadable at night. Second time went with the white - much better. Of course, never being happy, I pulled everything and replaced it with Dakota Digital.
