'74 Manual To Automatic Conversion?
Old Jan 14, 2016 | 05:17 PM
Richard Daugird's Avatar
Richard Daugird
Default '74 Manual To Automatic Conversion?
IS HE CRAZY?!?!? I see lots of info to swap in a stick, but what about going the other way? I know I could sell the car and buy one with an auto, just wondering.
Old Jan 14, 2016 | 05:22 PM
toobroketoretire's Avatar
toobroketoretire
I've done it several times and there's nothing unusual about it. If you drive in cities like San Francisco where there are a LOT of hills an automatic is the only way to go.
Old Jan 14, 2016 | 06:01 PM
fishslayer143's Avatar
fishslayer143
Crossmember is welded on a manual
Old Jan 14, 2016 | 06:03 PM
Richard Daugird
I have a Metabo and a welding machine...maybe fab an easily removable new crossmember?
Old Jan 14, 2016 | 07:36 PM
SH-60B's Avatar
SH-60B
That's what is generally done. You can use the other threads that swap a manual in, just reverse the process.
Old Jan 14, 2016 | 07:55 PM
69FASTFUN's Avatar
69FASTFUN
The trans tunnel is altered to fit a turbo 400 also
Old Jan 18, 2016 | 01:35 PM
Richard Daugird
I would be doing a 700R4, will the tunnel clear that?
Old Jan 18, 2016 | 03:50 PM
Alwyn678's Avatar
Alwyn678
I am not sure. I am not sure but you are using the best Automatic available. I put one in my 74 when I removed the Th-400 it is smaller. What are you doing with the manual set-up? I am looking to do the auto to manual switch on my 74. Let me know if you already bought your 700R4.
Old Jan 18, 2016 | 03:53 PM
SH-60B's Avatar
SH-60B
The TH700R4 will fit, been done dozens of times documented here on CF.
Old Jan 18, 2016 | 03:56 PM
Richard Daugird
I figured it would fit, all the searches showed auto to manual, not vise versa. I don't even have the car yet. I may love the stick as I no longer commute to Houston, and wouldn't use the 'Vette if I did. But over the last thirty years I've grown to hate stick shifts. I'm lazy!
Old Jan 18, 2016 | 05:01 PM
454Luvr's Avatar
454Luvr
When the TH350 died in my T-bucket, I swapped in a TH400. I originally wanted the 700R4, but a local shop said it would require a larger tunnel. Don't know if the tunnel in my T was smaller than in a Vette.
To '74 Manual To Automatic Conversion?
