Replacing brake pedal spring....impossible?
Old Jan 16, 2016 | 08:38 PM
Staylor63's Avatar
Staylor63
Default Replacing brake pedal spring....impossible?
I noticed my brake lights sometimes had stayed on after using the brakes, and after looking closer, the PO has a regular spring attached to the pedal and to the dash. Looking way up around where the pedal is attached, I don't see the orange coil return spring. I bought the spring, but it looks like I have to take out the dash and steering column just to get near it.
Has anyone ever done this task/mission before? Suggestions?
Old Jan 16, 2016 | 11:23 PM
cagotzmann's Avatar
cagotzmann
Auto or Manual.
There is no way around it. The pedal assembly will need to come apart. When I did my auto to manual pedal switch over I never found a way to do the work without removing the assembly from the car.
I also removed the seats to make it easier to lay on my back.
Old Jan 17, 2016 | 01:29 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Harbor Freight has a 12 inch long pair of needle nose pliers that I will use to install my brake pedal spring.........hopefully!
Old Jan 17, 2016 | 01:41 PM
Staylor63's Avatar
Staylor63
Originally Posted by cagotzmann
Auto or Manual.
It is an automatic. looking at aim, if I drop the steering column, and get the dash out of the way....I might have a chance!
Old Jan 18, 2016 | 07:19 AM
Mooser's Avatar
Mooser
I'm not sure there is enough room in the cavity to pull the pin completely out while the bracket is up in place.
The pin will pull part way out before it hits the side.
As I recall I couldn't drop the brake pedal itself, maybe there's enough room to get the spring it but somehow I didn't think so...
M
Old Jan 18, 2016 | 07:59 AM
jnb5101's Avatar
jnb5101
Mooser is correct. The pin is too long to remove. It was probably a fail-safe design.
Old Jan 18, 2016 | 08:23 AM
drwet's Avatar
drwet
Even if you could do it with the pedal assembly in the car, you would have to remove the steering column and instrument cluster. Once you have these out, removing the pedal assembly is no big deal.
Old Jan 18, 2016 | 08:36 AM
Staylor63's Avatar
Staylor63
Thanks for the insight guys! Not what I was hoping for....completely removing the steering column sounds monumental. Or is it easy as disconnecting a harness, removing the support bolts, unbolting the firewall plate and disconnecting the rag joint? Then it just comes out?
I want it right and this generic spring zip tied to the pedal now is driving me crazy!
Old Jan 18, 2016 | 08:47 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Yes, it is easy just as you have noted.
Old Jan 18, 2016 | 10:44 AM
cagotzmann's Avatar
cagotzmann
It all comes apart easy expect for 1 nut. The upper left nut of the brake booster (from the inside). You will have the same problem putting the nut back on. You need a series of extensions and u-joints to get at it. Its very tight. But once you get the right combination to remove it, write it down so you can use the same to re-install. I found that after this step the rest is just time.
Also be carefull removing you steering column. The 79 column fits closely around the dash pad and can easily damage the dash edges. It is easier with a helper, but it all can be done by yourself. To re-install the column I used a helper to guide it into place at the rag joint.
As for electrical connections I had problems figuring out how they came apart. Also take note of the brake switches and their position ( count the threads ) They move in and out quite easily so when they move you can set them back.
My 78 I had them out 3 times already during the auto to manual conversion. I am now on the 4th to fix a problem with the clutch pedal making noise.
Old Jan 18, 2016 | 11:39 AM
Staylor63's Avatar
Staylor63
It sounds like a plan...did you end up leaving the dash panel in place then?
Old Jan 18, 2016 | 11:53 AM
Mooser's Avatar
Mooser
Column is pretty easy (remove drivers seat of course) as you detailed.
The other thing to look at before you get too deep is if you can drop that channel that holds the brake pedal without removing the column support bracket. Maybe the two bolts can be loosened and the brake channel slide out but somehow I'm not convinced about that.
I think the drivers dash would need to be removed to get that bracket set off since it's bolted pretty high at the front
If you do go in that deep, that bracket set controls where the column sits in relation to the drivers dash (up and down / left and right).
There are 4 carriage style bolts that hold the two halves of the bracket together. If at all possible, leave those alone or you'll have to re-adjust everything when you go to put it back in.
If it was me, I'd go ahead and take it apart to get the spring fixed right but that's just me and I've been off the road for two seasons
M
Old Jan 18, 2016 | 11:58 AM
Shark Racer's Avatar
Shark Racer
If you have 1-2 u-joints and a good set of extensions, taking the brake booster nuts out is annoying but not awful.
One of the upper bolt threads retaining the pedal box was stripped, so I had to grind the bolt head off to get the pedal box out. From the wiper tray. With a dremel. That was awesome.
Old Jan 18, 2016 | 11:59 AM
cagotzmann's Avatar
cagotzmann
I only remove the speedo/ tach cluster and left the dash pad in place.
Old Jan 18, 2016 | 01:10 PM
jnb5101's Avatar
jnb5101
When you remove the column, bracket and firewall support, scribe lines in all pieces so that it can be reassembled in exactly the same(factory correct) position. That is, the steering box, rag joint and column are all in a straight line.
Old Jan 18, 2016 | 06:37 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Remove the dash panel. It's easy but note where the connections go especially the the dash bulbs! I made a little sketch.
To Replacing brake pedal spring....impossible?
