Wilcox- this is a great diagram. Can you tell me what the "low Blo" switch would be called so I can search and purchase it? My wiring diagram says "console climate mode switch"
Also, do you know where the heater resistor conn goes inside the car on an AC 68 car? I don't see it anywhere on the heater box.
Thanks!!!!
BUMP!!! I am still trying to figure out the "heater resistor conn" wire. I am thinking that AC cars don't use it? Has an orange blue and yellow wire with a white/clear female 3 prong connection. I have a heater resistor connection on my AC wiring harness in the engine compartment.
Look at one of my previous posts where i went into detail on what each component does, how it worked and what color wire went where. It is going to make your life easy if it is an ac car. I wrote it because I really struggled to get my system working.
