Changing/Draining Intake
Old Jan 24, 2016 | 05:15 PM
79vetter's Avatar
79vetter
Default Changing/Draining Intake
Hi - I want to change my intake but my block plugs are frozen/stripped. I don't want to mess with them anymore.
What are the other ways that I can drain the intake/block so that I don't dump coolant everywhere when I pull the intake?
Old Jan 24, 2016 | 05:33 PM
Calo69's Avatar
Calo69
St. Jude Donor '15-'16, '18
There is a temp sensor on drver side head should help if pulled.
Old Jan 24, 2016 | 05:49 PM
cooper9811's Avatar
cooper9811
In the past I have lowered the coolant level enough to change intakes by draining the radiator. You should be able to get the level low enough it drops below the where cylinder head coolant passages meet the intake. I've done it that way 3 or 4 times.
Have also used a shop vac to drain it from the top - I rigged up a rubber tube that extended down into the rad from the top (before I had my lift and I was too lazy to crawl underneath). Assuming you are replacing not reusing the old coolant.
Old Jan 24, 2016 | 06:03 PM
centuryoldracer's Avatar
centuryoldracer
This^^^^^^^^^^or you can use a piece of vacuum hose and go through the radiator cap and siphon a gallon or so. Takes a little while through the small hose but saves crawling. Use a small enough diameter hose to fit way down into the radiator.
Old Jan 24, 2016 | 06:25 PM
Shark Racer's Avatar
Shark Racer
Both rads that I've had on my car have petcocks on the bottom right corner to drain the radiator.
Old Jan 25, 2016 | 01:40 AM
79vetter's Avatar
79vetter
no petcock on mine
Old Jan 25, 2016 | 09:18 AM
REELAV8R's Avatar
REELAV8R
You can pull the lower radiator hose.
Or if you're really ambitious you can remove a exhaust manifold and remove one of the head bolts under it. The bolt runs into the water jacket.
Old Jan 25, 2016 | 11:16 AM
CanadaGrant's Avatar
CanadaGrant
Take the heater hose off the water pump. You don't even have to crawl underneath.
Old Jan 25, 2016 | 11:20 AM
centuryoldracer
Good one.
Old Jan 25, 2016 | 11:50 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Old Jan 25, 2016 | 01:54 PM
7T1vette's Avatar
7T1vette
If you don't want to get coolant splashed everywhere, just get a hose a syphon some out of the radiator. The coolant in the block will drop to the same level as the radiator.
Old Jan 26, 2016 | 06:38 PM
BOOT77's Avatar
BOOT77
Jack up the rear of the car high and drain/suck coolant out.
Old Jan 26, 2016 | 11:11 PM
7T1vette's Avatar
7T1vette
Geez.. Doesn't anyone know how simple it is to syphon fluid????
Old Jan 26, 2016 | 11:22 PM
cooper9811's Avatar
cooper9811
Agree - Only reason I lean towards a shop vac is because (if you have one) there is no need to deal with the nasty aftertaste. I siphoned many a gallon of gas from mowers or tractors to use in my old Monte Carlo as a kid.....
Of course we are talking about coolant not gas, but I'm still not fond of the taste.
Old Jan 27, 2016 | 11:55 PM
7T1vette's Avatar
7T1vette
Trade secret: Use clear tubing and pinch it off or seal it with your thumb BEFORE it gets to your mouth. You only have to get fluid in the tube dropped lower than the fluid level in the 'container' to start syphon flow.
Old Jan 28, 2016 | 08:04 AM
cooper9811's Avatar
cooper9811
Yeah, I know that - still didn't keep me from occasionally getting a taste.
Old Jan 28, 2016 | 08:10 AM
7T1vette's Avatar
7T1vette
O.K. It just sounded like you were trying to make the case for NOT syphoning anything.
To Changing/Draining Intake
Old Jan 28, 2016 | 08:14 AM
cooper9811's Avatar
cooper9811
Not at all - just saying if you're gonna play ball, be ready to commit the occasional foul.
Old Jan 28, 2016 | 09:11 AM
Luce's Avatar
Luce
The trick I used as a kid was seal the hose to the tank fill with your hand and a rag, then blow into the tank to pressurize it. Then quickly remove your face and the pressure will start the siphon.
For this endeavor, pull the heater hose, stick it in a jug, and carefully put pressure to the system with a air compressor. Then you can simply put the same antifreeze back in the car when you're done. If you don't have an extra piece of hose, pull it off the top if the manifold and put it into the jug and blow into the intake with the heater valve open if you have one.
Old Jan 28, 2016 | 10:30 AM
toobroketoretire's Avatar
toobroketoretire
I just put a 5-gallon bucket on the ground and siphon the coolant into the bucket using a 5 foot 3/8" hose. It only takes about 5 minutes to lower the coolant level to below the water pump.
