Need some Brake advice
NAPA, suggestion.......
If you are going with the CAST GM Calipers get units with best warranty. The O-rings I purchased from a corvette vendor advertised "life time warranty" I had 1 unit replaced under warranty. Then when I had the other units fail they would not replace them as the lifetime only covered leaks between the sleeve and the caliper and not the piston / caliper seal. I called BS on this misleading advertising. They have since removed the "life time claim" and now only provide 90 days.
So be careful with warranty claims. It needs to cover any kind of leak, since this is the main problem you will have with the calipers.
As for performance the only advantage I saw with wilwood vs GM Calipers was at the track. Much less brake fade due to better cooling. As for leak proof, I dont know yet, they have been on the car for 1 month driving and 3 months storage.
The only thing the wilwoods require to fit is additional washers on the caliper bolts to prevent the bolt hitting the rotor in the rear. The fronts fit perfectly.
Now for the BAD of the wilwood calipers. To bleed the rear calipers you must remove them and set them vertically or you will NEVER get all the air out. The problem is the position of the bleed screw and the position the caliper mounts in the rear. It is installed almost horizontal allowing air to be trapped above the bleed screw.
I was prepping for a track day that required me to bleed the brakes, so I decided to give it a try.
Finish was really nice on the new units, and they came already painted grey. Had them 2 summers now, and even with 6 months storage, I've had no issues at all.
The Wilwood's with shipping, tax, and duty would have cost me three times as much......not worth it for my style of driving.
it a part that is not buried behind 12 hours of wrenching like a rear end gear, or a wheel bearing, it can be accessed with the wheel off, so to me i would go for it.
but i went cheaper yet....orilly rebuilds, with a military discount ~65 bux
