IIRC, in his book, Dave McLellan says they wanted to test the fiberglass spring in a real world situation in prep for the C4. They considered there would be more 81 AT cars than there would be 4 spds. They expanded the test group for 82: all of those have the fiberglass spring.
I have an '81 with automatic and the composite spring. My rear wheels have been squatting and it seems like the suspension bottoms out when I hit a bump so I took it to a tire shop for an alignment this morning.
As soon as they lifted my car they noted that the rear spring was split and said that was causing the bottoming out effect.
I now need to buy a new rear spring for the '81 so I have a few questions as my car is NCRS Top Flight and I want to keep it original as much as possible. The car only has 46k original miles.
Where should I buy one?
What is a fair price?
Are there other parts I should replace while replacing the rear spring?
How difficult is the replacement of the rear spring? I consider myself a fair to decent mechanic but would not attempt an engine or transmission rebuild. I have a heated basement garage and most kinds of tools.
What would be a fair charge if I hire a garage to replace the spring?
If you have ANY mechanical inclination, a few sockets, a floor jack, and 2 (preferably 4) jackstands, then replacing the rear leaf spring is easy.
We're talking about 4 bolts in the middle and 1 bolt at each end. That's it.
I would replace the rubber at the ends of the spring when replacing.
The new spring SHOULD come with new rubber for the center. If it doesn't, then get that kit too.
Be sure not to over-tighten the center when reinstalling. Really, you're just talking about holding the spring in place...to keep it from flopping around. The weight of the car will do 90% of the work.
For me, this is a 1 hour job. More time is spent getting the car up and the wheels off than the actual act of tinkering with the spring.
Thanks for the great info.
I looked at Mid-America's website and the cost of a fiberglass spring is $319.99--Just a wee bit pricey!
Any other sources I should check?
Apparently of the 40,000 cars made in 81, 5000 or so were 4 speeds with steel springs.
Seems it might have something to do with the two different assembly plants that year.
In California, however, the 4 speed was illegal and in that state all cars were automatic.
Sorry if i confused anyone.
I believe you're thinking of the 1980, California (305) model, as the '81 was definitely available in Cal. with a manual tran.
One other bit a trivia, '81s ordered with autos and Gymkhana suspension got the steel spring. (At least that's how I interpret the Black Book) Mine was a 4-speed, with Gymkhana, so I know it had a steel spring.
The 81/82 composite was very weak .. 192 lbs....and was gms attempt to give the c3 a nice soft ride....I would look at a 300lb composite at a minimum..
I see the 192 Lb. and 300 Lb. and the various other ratings on the springs.
What exactly or how is this rating determined? Obviously the higher the rating the stiffer the spring will be, but how do they determine those numbers?
This may be one of those situations where NRCS-type parts get you the points, but aftermarket components are considerably 'better' than stock.
Gonna have to make a choice, it seems.
I agree with that logic since the replacement composite springs cost 2 or 3 times as much as the metal springs and would not pass NCRS scrutiny I think I will go with a metal replacement spring if it will fit my '81 with automatic transmission.
Can anyone tell me for sure that they are interchangeable without cutting/welding? I am a fairly good mechanic when replacing bolt-on items but do not do cutting and welding.
This is the first I have heard that the stock composite springs are 'soft' and it might be better to look at either a stiffer composite spring or going with a leaf spring. Is this generally true?
I do not believe there are any modifications required to go between fiberglass and steel springs. At worst you'll need longer bolts if there isn't a 'make up block' in the current fiberglass spring stack where it is held onto the center section.
