Interior Dye/restoration help
Old Jan 29, 2016 | 12:10 PM
RizVet's Avatar
RizVet
Default Interior Dye/restoration help
I got my hands on a replacement 71 lower shifter console. It has some scratches. If I dye it I'll be forced to do all the interior pieces to match the "newness" right? Or do you think their is a dye out there that might just bring it back to life a bit and will blend in with the existing black interior pieces? thoughts? Comments please. Also, what is the best product on the market to dye the console? Spray can or rub on?
Old Jan 29, 2016 | 01:08 PM
blue by you's Avatar
blue by you
All depends on the condition of the rest of the interior, i would sem dye and do a sample to see how it looks. All coros are different some match to the old some are alittle off.
Old Jan 29, 2016 | 01:44 PM
530planeman's Avatar
530planeman
If you al SEM in south Carolina they can tell you the closest dealer and most can match and put it In a spray can mine did
Old Jan 29, 2016 | 03:00 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...If I dye it I'll be forced to do all the interior pieces to match the "newness" right?...
Forced? No. You can decide which way you want to go after it's restored and installed.
Old Jan 29, 2016 | 03:05 PM
Alan 71's Avatar
Alan 71
Hi R,
In the worst case if the newness of the black on the shifter console bothers you you'd just have to dye the 2 forward extensions and the e-brake console too.
They'd match each other then.
Even originally the shifter console was black padded vinyl while the e-brake console was painted interior black so they always looked 'slightly' different.
Good Luck!
Regards,
Alan
Old Jan 29, 2016 | 04:15 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I dyed my new replacement parking brake console green and it matched the rest of the interior near perfect. Don't skip the primer phase and use several thin coats.
Old Jan 29, 2016 | 04:23 PM
530planeman
Many thin coats is best do not thin paint
Good luck
Old Jan 29, 2016 | 05:57 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
SEM satin black is good for vinyl parts, and Landau black for metal pieces(bezels etc.)
Greg
Old Jan 29, 2016 | 10:08 PM
RizVet's Avatar
RizVet
So SEM satin black is the best match?
To Interior Dye/restoration help
