New choke pull off
Old Jan 30, 2016 | 02:41 PM
Wibäck's Avatar
Wibäck
Default New choke pull off
Hi all
Got this new replacement choke pull off for my 1975 l48. What bothers me is that the new one has three little holes in the back that sort of let air in when I suck on the pipe where the vacuum hose goes. What purpose do they serve? Won't they cause a vacuum leak?
I guess I should plug them up in some way. Suggestions?
Cheers!
Fredrik
Old Jan 30, 2016 | 02:46 PM
toobroketoretire's Avatar
toobroketoretire
Those holes are there for a reason so don't plug them. The manufacturer spent additional money to make it that way (maybe to limit how hard it'll pull).
Old Jan 30, 2016 | 02:59 PM
Wibäck's Avatar
Wibäck
Why hasn't the old one got them then? There will be a vacuum leak through these holes, no?
Old Jan 30, 2016 | 03:29 PM
righthanddrive's Avatar
righthanddrive
The old one looks like it has one hole. They probably added holes for quicker reaction time. I doubt that it will cause leaking because there should be a diaphragm that moves inside
Old Jan 30, 2016 | 03:30 PM
righthanddrive
Cut the old one apart and you'll see why they are there
Old Jan 30, 2016 | 03:49 PM
olescarb's Avatar
olescarb
the rear choke break on that carbs an auxiliary choke break which delays in its operation by bleeding off some of the vacuum thru those vents. unless the vehicle is being operating in REAL cold weather we most often do not use that choke break but the primary choke break must work properly.
Henry @ oles carb
Old Jan 31, 2016 | 02:51 PM
Wibäck's Avatar
Wibäck
The old one seized up and stopped "pulling". Therefore the block for the secondaries was never released and the car lacked that "unf" when I floored it. I will mount it as is then and see how it works.
// Fredrik
Old Jan 31, 2016 | 08:08 PM
REELAV8R's Avatar
REELAV8R
Inside the can is a diaphragm. When the diaphragm moves or flexes from applied intake vacuum, then the air behind it has to move too. Those holes prevent a vacuum behind (wrong side) of the diaphragm which would limit it's movement.
Think of a syringe. If you plug the end and then pull the plunger up it creates a vacuum behind the plunger inside of the syringe.
If you lack sufficient force to pull the plunger with a vacuum being created on the back side then you limit the travel of the plunger.
Old Feb 2, 2016 | 01:37 PM
lars's Avatar
lars
The rear choke break is not needed and serves no practical purpose. It was used on Chevy passenger cars in 1975 only, and was deleted in 1976+. Even if it's inoperable it will not prevent the lockout lever from retracting, and it will not prevent the secondaries from operating. If your fast idle cam is not dropping down to the full low position (this is what retracts the lockout lever), you have problems not related to the rear pulloff. Suggest you delete the rear pulloff and just set up your primary choke pulloff correctly. Then, find the problem with your fast idle cam not retracting the lockout lever.
Lars
To New choke pull off
