My Driving Lamp Project (pics)
I asked for it so thanks for the reply! I would not expose myself to criticism needlessly. Besides there seems to be some interest in this thread. Many lurkers benefit also.
My Plan B is to take that red-hot-fused wire off the distributor feed (no harm done because of the scotch-lock) and run it back to the battery + terminal from the underhood switch-fused. I will have to do some rug-lifting but what the heck ;) . That will give a direct, uninterrupted 12 volts to the lamps. Or drop it down to the + on the starter. But I worry about that. But I sure do like those lamps. They give me visibility on the highway that I have wanted for sooooo longggg!
[Modified by paul79, 9:42 PM 9/3/2002]
posting. They have turning lights and halogens wired to switched 12V circuit.
Cant be much simpler than this.
Then your driving lights wont turn on before the motor has started and you have full battery power to the starter.
great overall effect. except for the fine tuning a job well done. another project on my things to do list...(it seems the more i hang out here, the more projects get added to that list... hmmm. check book feel lighter too!)
Some critiques. Instead of electrical tape i would use heat shrink tubing. its a little more attractive and gives a better seal. id also look around for a more attractive light switch. on my wifes jeep here fog lamps have a real small push-button in a box switch. it quit a bit smaller than the switch you have.
[Modified by Got79Fever, 11:39 AM 9/4/2002]
Dave said:
Here is how it works: You turn the key on and the relay coil is powered by the yellow wire at 12v. If the parking lights are off, then the GND side of the relay coil will conduct through the parking light bulbs, but not enough to turn them on. The relay will now be switched on and the driving lights will get power from the alternator - via the relay. NOW - turn the parking (or head) lights on. The headlight switch supplies 12v to the GND side of the relay coil - with 12v still applied to the power side of the relay coil. With 12-12= 0volts across the relay coil, the relay turns off, and the driving lights will be off.
I believe you can buy different styles of relays... A normally open relay (off) or a normally closed relay (on). Radio Shack would probably have these relays. I would use a normally closed relay. I would wire right from the alternator to the relay, then to the driving lights. Then use the low beam power to turn on the relay, which would open the switch for the driving lights. This way the driving lights would turn on when the car starts. The driving lights would work when the parking lights are on (Might be good if the headlights don't want to pop-up), turn off when the low beams are on.
Since the low beams stay on when the high beams are on, I don't know how to hook it up so that they will work with the high beams and not the low beams. :confused:
Awesome job, congratulations on your work. I actually had thought of putting lights back there when I was in HS, but never had the nerve to try it. Damn, that was 10 years ago! Anyway, it all looks great and you are truely an example I follow whenever I do anything on my 79. You have done a great job with your car. :cheers: :cool:
I heeded the advice on not connecting to battery power at the distributor. Possible damage to the ignition module. Made a lot of sense! The scotchlock is gone. So now I must tap the battery directly from the underdash switch. But a lot of wiring through the rugs to the back. Why not tap battery power at the fusebox? So I looked in my Service Manual for an ignition-switched circuit that was not being used. And independent from all other accessories/circuits. Found one. You see it below: the auxiliary cooling fan. This is an option I do not have. Tested that port on the fusebox and it was live and switched by ignition.
So I tapped it! Driving lamps now work fine on an independent, ignition-switched circuit. Many thanks to all for advice and your patience! So many useful tips....What a learning experience! And the underhood switch is tacky so I will look for a replacement.
[Modified by paul79, 6:48 PM 9/4/2002]
[Modified by paul79, 8:42 PM 9/4/2002]
They light up the night as well. Pretty impressive for such small lamps. But they are too bright for use after dark. So they are DRLs.
[Modified by paul79, 9:48 PM 9/4/2002]
[Modified by paul79, 10:14 PM 9/4/2002]
don't see this many hits on a tech topic.
John is right - a normally open relay would be the best option for what I described, but I didn't want to send you out shopping.
:seeya
I really appreciated your advice. Thanks! In the end I went with the simple circuit seen below. The Hella plastic switch was discarded today and a robust 20-amp toggle switch was placed under the dash where it is hardly noticed. I am finished fooling about. Time now to drive. Weekend looks like very nice sunny and mild weather. Not too many left before winter :( .
[Modified by paul79, 10:18 PM 9/7/2002]
