Solid Axle Conversion
Old Feb 2, 2016 | 04:21 PM
1980Guy's Avatar
1980Guy
Default Solid Axle Conversion
Hi all. For a couple of years I have been worrying about the Dana 44 IRS in my '80. I know that although my car is an automatic car, I have the diff from a manual car. I'm assuming that it was blown up at some point. After looking at how difficult/expensive it is to beef those up or swap them to iron diffs that are only marginally stronger, I'm seriously considering doing a four link conversion with a 12 bolt solid axle.
I'm interested how satisfied people are who have done this, because it doesn't seem easily reversible. While I would like to able to safely drag race the car at my local track, I don't want it to be a drag car, per se. I want it to be a solid road track car that can haul in a straight line if I want it to. How does the 4 link affect the handling? Better/worse?
Old Feb 2, 2016 | 06:31 PM
rcread's Avatar
rcread
It sounds like you are interested in keeping it a sports car. A solid rear axle will definitely detract from that aspect.
Old Feb 2, 2016 | 11:09 PM
fishslayer143's Avatar
fishslayer143
Old Feb 3, 2016 | 12:31 AM
htown81vette's Avatar
htown81vette
Although myself I'm not convinced, there are many people that argue that the Dana 44 is plenty tough already.
Unless you were making a 9 second drag car I wouldn't do it.
IF your just running street tires I definitely wouldn't worry about that rear end. If you were pumping out 600 hp and running slicks then I might worry.
Old Feb 3, 2016 | 01:21 AM
diehrd's Avatar
diehrd
I second htown81vette
Old Feb 3, 2016 | 09:24 AM
454Luvr's Avatar
454Luvr
A solid rear is absolutely unnecessary unless you expect to be well above 600 HP. Even then, the older iron rear can be made pretty tough. There's no need to ruin the car like this unless you're planning an all-out big block.
Old Feb 3, 2016 | 09:35 AM
Ibanez540r's Avatar
Ibanez540r
I was suprisingly shocked last weekend while at a friend of a friends house and walked into the garage to see an 81-82 vette setup strictly for the strip. Car has slicks on it, runs low 11's, so asked him what he has done to the rear end...
Nothing. All stock.
This goes against what I have seemed to believe on here about tires being a fail safe and not putting much power AND grip on the stock rear end. Apparently it can be done.
Old Feb 3, 2016 | 01:52 PM
1980Guy's Avatar
1980Guy
Thanks guys. Eventually is like to do a turbo LS swap with a 6 speed. For now it's a ~375hp smallblock with a TCI 700R4. I have driven solid axle MGB's and really liked the way they handled, but they were designed for that from the get go. The Vette was designed around the IRS. I guess I will leave her stock and trust the Dana 44. I'm running street tires right now and will continue to do so in the future so hopefully it's not an issue.
Old Feb 3, 2016 | 03:34 PM
7T1vette's Avatar
7T1vette
Trade your Corvette for a Camaro or Firebird....
Old Feb 3, 2016 | 03:58 PM
1980Guy's Avatar
1980Guy
Old Feb 3, 2016 | 06:13 PM
tektrans's Avatar
tektrans
That's too bad..........
Old Feb 4, 2016 | 09:17 AM
1980Guy's Avatar
1980Guy
Drool. How does it do in turns?
Old Feb 4, 2016 | 05:42 PM
7T1vette's Avatar
7T1vette
{reply for 1980guy}
Old Feb 4, 2016 | 06:36 PM
tektrans's Avatar
tektrans
There's no turns in a 1/4 mile
Seriously-it's fine in turns, certainly not as good as an IRS set up lets be realistic but for street driving and 1/4 mile racing it's a perfect compromise for me. Plus it was $6k less than a Toms set up.
Old Feb 4, 2016 | 10:07 PM
fishslayer143
I LIKE IT!!! any issues on tire/frame clearance?
Old Feb 4, 2016 | 10:28 PM
diehrd's Avatar
diehrd
What spring rate did you use on the rear
Old Feb 5, 2016 | 11:36 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
There's a gazzillion solid axle cars going around corners very quickly. I don't know that an IRS is as giant an advantage as folks think it is..especially for a typical street car.
JIM
To Solid Axle Conversion
Old Feb 5, 2016 | 11:38 AM
diehrd's Avatar
diehrd
Looks like my car just lost its complete rear end ,, What should I put in her place ?? I decided ... Fab 9 .... 4.11 . TrueTrac .
Old Feb 5, 2016 | 05:00 PM
tektrans's Avatar
tektrans
for those tires yes-I had to clearance the frame a bit-not bad though wasn't hard.
Old Feb 5, 2016 | 05:01 PM
tektrans's Avatar
tektrans
I believe they are 150's.
