Serpentine Conversion with 3rd gen Fbody mounts question
if you want something pretty, I think you should start with another system (billet ?).
this one is functionnal and reliable, but as most OEM parts, it's not designed to look good imo.
http://marchperformance.com/chevy/ch...sive-kits.html
Here's a picture of mine from and 89 Firebird donor during my build. I used some aluminum paint, March underdrive pulleys and Victor Jr. reverse flow water pump to dress it up.
The amount of work you put into clean up and painting will obviously impact the overall look. The piece you pointed out is required for keeping tension on the belt, as Mike80 says.
Its 900 bucks from summit with all new accessories, which is basically 350 just for the brackets with out. Seems like its only a deal if I can find it and pull off a car.
I have about $400-$450 total in mine, including an unused AC Delco AC compressor that I found off of craigslist for $100.
It takes time and patience but can be done for a reasonable cost.
Second, are you guys using the 3rd gen AC compressor with this or does the c3 one match up, or maybe they are the same? My car was missing AC when I got it so I have to buy the compressor anyways, so if I am better off, I will just go with the 3rd gen since it was 'intended' for this setup.
Which water pump are you guys using with this, I see edelbrock makes a bunch of options and I guess my google-fu is weak here. Just a 3rd gen Camaro performance one? If you have a part number, I would be very happy.
Why the underdrive pulleys? Did the other pulleys not fit right? And I see March offers 3 types of pulleys now too, which did you go with.
Anyone keep a mechanical fan on it, I see from other posts online that the mechanical fan from a 1996 Jeep Cherokee bolts right up and fits. I am leaning this way so I dont have to tackle electric fan swap at the same time.
can't swear to prices today, but look around.....I dunno about other car sources, and I am a junkyard hotrodder for some decades now.....
Here is a summary of what I dealt with:
- I switched over to the Camaro power steering pump (not required, I just needed a pump anyway and I got one with the correct pulley) - If you do this, take the inlet fitting from your old PS pump and put it on the new one, so your PS hoses still bolt up.
- I had to experiment with water neck and radiator hose combinations to avoid rubbing on the belt. I found on that pointed straight forward and looked for a suitable hose at a local parts store.
- The lower rad hose is the stock hose, but required trimming and may sit tight against the lower cross member.
- You will have to convert to the later style alternator (CS130 or similar). I used a pre made pigtail from Summit to ease the conversion.
- I used the water pump for a 92 Z28.
- If you have AC, you may need a later pancake compressor. I was not able to convert my stock C3 pancake compressor to a serpentine pulley. Going with a later AC pump may also require an adapter to the older style AC hose block. AC specialists can set you up with an adapter. I called Classic Auto Air and they set me up with a washer/adapter kit that works well.
If you don't have AC just run the AC delete pulley. - The air pump delete pulley is not required, and I didn't use it. If you choose to run it. You may need to clearance the bracket and flip it over. The long straight run between the AC compressor and crank pulley has not given me any problems.
- I also had to reroute the fuel line - if you go with hard lines, will take a little massaging to ensure you don't rub anywhere. I still ran up the front of the block, but you have to work around the brackets so stock line won't work. Not hard, just took a little patience.
- Stock 92 Camaro pulleys all worked and cleared the crossmember - you mentioned underdrive pulleys, and other members have used them. I did not need to go that route.
What do you guys think the advantage is over the old short pump belt drive set up is? I don't think that's particularly ugly and I do plan on going to electric fan(s) and THATS another pile of decisions too! But other than a newer look and only one belt, any real advantages?
Lots of planning' being done over here!
Thank you.
-Walt
Cost can be reduced significantly if you are willing to be patient and take your time looking for parts - I have about $400-$450 total in mine (including finding a deal on an AC Delco AC compressor locally), so I'm in for about half of what the GM setup will cost new.
I would still do it again, even with the list of times I had to car for in my earlier post.
Thank you.
-Walt
Besides looking nicer, this gives you a more efficient PS pump AND AC compressor if you go that route. And, obviously the single belt design is very trouble free. I personally feel the aftermarket kits are way overpriced since you're only getting a bit more eye candy for the money-I'd put that cash elsewhere on the car.
I also think the serpentine drive looks cleaner (even the factory setups off of early 90s F-bodies)
But, understanding now that I may have to repave my pancake A/C compressor, plus probably the alternator and P/S pump, I think I'll just do my version of a super-clean, paint and reassemble the old style set up to get the car rolling again by summer. I took it apart in August of 2015 and really miss my baby! I will keep on the look out for a deal on a serpentine set up though.
Now a final question that I can't seem to find an answer to. What is the maximum CFM pull-through of the stock fan and shroud with the factory correct functioning clutch drive? Anybody publish that info?
