decode motor numbers pleese
Old Aug 31, 2002 | 07:02 PM
mixtli's Avatar
mixtli
Default decode motor numbers pleese
Can somebody tell me if this is right motor for my 71.
vin is 194371S113282
2 sets of numbers on deck 011S113282 and V0316CJL
if you can deciper or point me to website that would be good.
thanks
Mixtli
Old Aug 31, 2002 | 07:48 PM
Larry B.'s Avatar
Larry B.
Default Re: decode motor numbers pleese (mixtli)
It appears that you have the original engine. The suffix CJL tells that you have a 270hp 350 with manual trans. Since the vin and the engine stamping coincide it is most likely the original engine. The only other possibility is a re-stamp which is not likely with the more common cars. Re-stamps are mostly found on NCRS restored or rare cars.
Old Aug 31, 2002 | 08:00 PM
Tahos's Avatar
Tahos
Corvette Black book lists suffix for 1971 "CJL:350ci,270hp,mt".Look for your
casting number and post it.It should be on bellhousing flange at the rear
of block.
Old Aug 31, 2002 | 08:05 PM
kennersonm's Avatar
kennersonm
For the VIN
19437 = Corvette Coupe
1 = 1971
S = St. Louis
1 = ?
13282 = sequential number produced that year
The 011S113282 stamping on the motor matches = original
Out of curiosity, is there a blue sticker on the drivers door with the VIN on it?
Also, check out 1971 Corvette Registry, it has some good info there.
Matt
Old Sep 1, 2002 | 07:42 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
Default Re: decode motor numbers pleese (kennersonm)
I think that extra one is a checksum number
Old Sep 2, 2002 | 09:54 AM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Default Re: decode motor numbers pleese (silvervetteman)
:lol: :lol: :lol: :lol: :lol: :lol: :lol:
To decode motor numbers pleese
