GM limited slip additive
Old Feb 8, 2016 | 09:10 AM
clatgeo's Avatar
clatgeo
Default GM limited slip additive
How much GM limited slip additive would you add to a posi differential that holds 3.7 pints (59.2oz)?
Old Feb 8, 2016 | 10:01 AM
bashcraft's Avatar
bashcraft
I would buy the gear lube that has the additive already in it.
Old Feb 8, 2016 | 10:03 AM
keithinspace's Avatar
keithinspace
I went to my Chevrolet dealership to buy the gear oil and posi additive.
It was two bottles of gear oil and one little bottle of posi additive.
I went to GM to buy it for the very reason you're asking the question...I wanted to be sure I added the right amount of the stuff.
Old Feb 8, 2016 | 11:00 AM
zwede's Avatar
zwede
In my experience the oil that already has the additive in it doesn't work. I still had chatter. Only thing that works is the GM additive.
One bottle is what should be needed. GM says a second bottle can be added if chatter persists (this is the official fix for some new Camaros).
Old Feb 8, 2016 | 11:09 AM
bashcraft's Avatar
bashcraft
I've been using it for 37 years with 3 different rear ends. Never had any problem.
Old Feb 8, 2016 | 11:16 AM
jb78L-82's Avatar
jb78L-82
Mobil 1 75W-90 GL-5 with no additive for 26 years now...zero chatter. Works great and is synthetic....
Old Feb 8, 2016 | 11:34 AM
zwede's Avatar
zwede
That's why I started out with "In my experience". YMMV
Old Feb 8, 2016 | 01:31 PM
Reaper19's Avatar
Reaper19
I just changed mine, bought 2 quarts of Valvoline High Performance 80W/90 with limited slip additive already in the bottles, but also added a 4oz bottle of GM limited slip I picked up at the dealer. That was the consensus with most forum users and the dealership. Most dealerships around here no longer carry the original part number product gear oil and said just use any good 80W/90, but also recommended Valvoline. plus it is a lot less expensive.
To GM limited slip additive
