As the engine is warming up and after the carb kicks down to idle I've been hearing a rattling noise as if it's a lifter ( my take on it ) however this weekend I had the heater on while warming up and the rattling never happened . ( ran the car Sat and Sun ) any ideas? Oh and the noise only last a second or two . And never once the engine is hot .
have you opened the hood while the noise is occurring and attempted to determine the source. You can use a short piece of rubber hose as a stethoscope and move it around to locate the source.
The PVC valve is the forward plug / fitting on the valve cover, 2 types . The first picture is what was on the motor before the rebuild - not correct, the second is the correct one. The line usually has a T in it. Carb to PVC and then to Vac Tank.
Have had hood open and closed with the same sound .... I'm gonna replace the pvc just to see if that's it ..... Problem is the sound only last a second or two , no time to get the rubber hose like you said .. But thanks a million for the help ....
