81 rearend rubber bushing-replace....
Old Feb 10, 2016 | 06:08 PM
ramair_bryan's Avatar
ramair_bryan
Default 81 rearend rubber bushing-replace....
Fella's........boy it's been a year I bet, since I posted anything.
But here's a question I need help with.
I need to change that rubber bushing under the rearend on our 81.
Anyone have a youtube vid or just some advice getting it out and in?
Make this real easy.............
Bryan in calif. 72 degrees and sunny....
Old Feb 10, 2016 | 09:02 PM
mortgageguy's Avatar
mortgageguy
72 degrees! All I can say, is, 50 more mornings to April. So, I replaced my snubber when I put the diff in after a rebuild. I think you'll need to remove the drive shaft to give yourself enough room to get to it. It is tight. I hope someone else will chime in to confirm. Mine is a 72, there might be some differences in the 81. I don't know if you will have to remove the mounting bracket or not. It's not difficult, but it is awkward.
Old Feb 10, 2016 | 10:28 PM
ramair_bryan
Thanks for the reply.
I was looking over youtube vids, and noticed the earlier models have a front bracket/mount pad that can be unbolted for easy access.
Such lucky people...
Not so on the bat wing cars.
Old Feb 10, 2016 | 10:45 PM
mortgageguy
So, the 81 doesn't have the bracket? How is the front of the diff attached to the frame?
Old Feb 10, 2016 | 10:58 PM
ramair_bryan
They cast it into the carrier housing, then drilled a hole.
Sucks........
Old Feb 10, 2016 | 11:10 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The snubber cushion is not that hard to replace on your car. The issue you'll have is that all that is available is the 1979 and older style which will require you to slightly enlarge the mounting hold in the front.
http://repairs.willcoxcorvette.com/1...-instructions/
Willcox
Old Feb 10, 2016 | 11:42 PM
ramair_bryan
Yes......thanks willcox.
However, I can't pry that thing down for nothing or nobody.
Bolts out, seems loose, but it requires something more to pull that thing down.
Cars on jack stands placed on the frame (under bird cage).
I thought rolling it up on ramps may take the load off, But nope.
So I removed the spring bolts from the trailing arms as well.
Nope.
Ok.....who you gonna call.......
Old Feb 11, 2016 | 09:18 AM
newbie2vette's Avatar
newbie2vette
Nope.
There's no moving that diff to repalce that bushing unless you losen the two bolts that holds the cross member. Spray some rust free type lubricant around the mounting pad (cone shape), then losen the two bolts that holds it. DO NOT REMOVE them all the way. the lubricant should losen the mount pad to the point it will drop on its own, if not pry on it until it drops. That should give enough room to move the diff and extract the large bushing. good luck.
Old Feb 11, 2016 | 10:00 AM
ramair_bryan
Ok........the cross member your talking about is what the bat wing
is bolted to, correct?
I removed the two bolts. Maybe I better slide them back in. and try again.
I noticed the bracket attaching the strut rods could be loosened, and
maybe that would let the rear rotate down. With the jack supporting.
Keep it coming guys.
Old Feb 11, 2016 | 10:49 AM
hugie82's Avatar
hugie82
There's a trailing arm bushing video on you tube that does a good job on how to break down each side. Dropping the batwing is pretty much self explainitory. Those bushing hold up pretty good and if they don't look bad, I would leave them alone. The trailing arm in the tough one if you have the high mileage , well used corvette. A sawzaw will be your friend. I'll be doing mine this winter on my 82.
Old Feb 11, 2016 | 01:34 PM
newbie2vette
My apologies. I forgot to mention the leaf spring must be disconnected from the trailing arm. Yes. I recommend you put the bolts back in and live them lose, and as mentioned losing up the strut rod mounting bolts will also allow the diff to move easier.
Old Feb 11, 2016 | 01:42 PM
bschuus's Avatar
bschuus
I did my 80 a few years ago. I think I had it on ramps. I believe I used my 3 foot pry bar. Not fun
Old Feb 11, 2016 | 02:41 PM
ramair_bryan
Im headed back out to the barn. cover me.......
Old Feb 11, 2016 | 03:43 PM
ramair_bryan
So close........
I'm need to count my fingers when I get finished...
Old Feb 11, 2016 | 06:44 PM
ramair_bryan
I have to knock off for today.
Put the bat wing bolts back in to hold things. (loose). Removed the end bolts for the leaf spring to take pressure off of the diff. Put the floor jack at the spring/diff mount. That makes the diff easier to pry downward.
Fighting a leaking down floor jack. Like I have 3 hands. (Lucky if I have all my fingers when I get done)....
Thanks willcox for the pic. Rest of you guys too.....
Old Feb 12, 2016 | 05:30 PM
ramair_bryan
Okay.......................Whew, Got it done. Not going there again. I took a look at the rubber type, and made a Teflon bushing to fit in it's place.
Now I'm bleeding the brakes. (And I'm bleeding as well).
Another problem arose as I'm removing the RH wheel. Nuts are off, wheel is loose, But I can't slide the stinking thing off the lugs. Just rocks. I'm thinking I'll put the wheel back on
Drive the car back and forth with the nuts loose and see if it make a diff.
Old Feb 12, 2016 | 06:47 PM
Sluefoot's Avatar
Sluefoot
Sounds like some corrosion between the wheel & the hub.
I always put a layer o' Anti-Seize on the hubs B4 putting the wheels back on.
Your plan o' attack sounds like the best approach....Good Luck!
To 81 rearend rubber bushing-replace....
Old Feb 12, 2016 | 07:48 PM
croaker's Avatar
croaker
Day late but I read to use a block of wood to hold it in place before Unbolting. I used a chain and pry bar
Old Feb 12, 2016 | 10:35 PM
ramair_bryan
Block of wood.............Give me some more info. Sounds like it's in my budget....
p.s. This wheel always does this. I just keep forgetting.
(hard to find good help).
Old Feb 12, 2016 | 10:39 PM
mortgageguy
Will a Teflon bushing transmit more road noise than rubber?
