You got it. It is much less messy without filling the tank and the air pressure is all you need to do the job. I pressurize the tank at 15 psi and let it set for a couple of minutes to make sure I have a great seal with the c-clamp.
I just worry that the reservoir will go empty seeing the calipers are bone dry.
Hope the suggestions using C clamps works...For all and any forum members looking to purchase a used "one time" to pressure check the system Motive Bleed Kit I will make them a very good price offer....
I had better luck using the "gravity bleed" procedure....
mk's78
Mike
I don't have a Motive bleeder, I have a 20 year old Snapon, so I don't know how the Motive is set up. As suggested, use a quick connect where the hose attaches to the plate that covers the master. Doing this allows for a male fitting to be inserted into the quick connected to bleed the air from the line before connecting to the plate. While bleeding, I always keep brake fluid in the unit, you have to remove the plate to constantly check the fluid level without it. You really don't want to be sending air down into the system. I place rags, old tee shirts under and around the master to catch any fluids. Not only are you bleeding the system, you are also flushing it, bleed until you get clear, clean fluid. Connect a clear hose to the bleeder fitting and down to an empty 20oz plastic bottle. Put the hose close to the bottom of the bottle and as the bottle gets some fluid in it you should see the small bubbles of air come out. When you move to another wheel, don't forget you will get bubbles as the air empties just from the hose itself. When your done and the pedal is nice and hard, pop the bleeder plate off, use your new turkey baster to bring the level to spec's and put the lid back on. Check the condition of the rubber liner on the lid first.
Great tips guys....I really appreciate yall taking the time to walk me through a couple of things. This sounds much easier than the old way of pumping the brakes.
Hello Mike,
I'm interested How good a price
Marshal
mk's78
Mike
Do not pump the Motive to high pressure. If the pressure is too high, the fluid will fill the calipers so fast that air bubbles will be trapped. Also, tap the caliper with a rubber mallet as it fills to help dislodge small bubbles.
I didn't get instructions with the Motive (odd). But from what I am tracking you only pump it up to 10psi let it sit to verify no leaks and then start bleeding.
10 pounds is excessive. 3 or 4 pounds pressure is more than adequate. The fluid has a very low viscosity and doesn't need much force to force it through the lines. A lower pressure may take a few seconds longer to fill the calipers, but fewer air bubbles will be trapped.
Sending some good vibrations into the caliper is a good point. It doesn't have to be a rubber mallet if you don't have one. A wooden hammer handle, small brass hammer, screwdriver handle, anything to get some vibrations going. I start out with putting 25 psi in my system (snapon), it has a large tank and a long hose so there is some pressure drop, but I don't have to keep putting air back into it after each caliper. 10 psi might be a lot for the Motive tank, I would try what the manufacturer recommends, try their web site. I do each bleeder multiple times before moving on to the next wheel or until I don't see any more air bubbles (clean, clear fluid). Bleed the wheels in the correct order and I usually do it one more time after I get a good pedal just to make sure. If you have a particularly difficult time, I have used Russell speed bleeders in the past that solved the problem. Patience is the key and maybe a beer or two.
Finally got a chance to use the motive tonight.....AWESOME product. Used two C clamps and filled the tank with dot 3. Took about 45 min total to bleed the rear. Very very pleased.
Update....bleed the brakes and thought I had a bad caliper on the passenger rear because there was a small leak on the bottom of the trailing arm under the hub assembly. This leak only presented itself after I pressure tested the system at 10 psi (held that pressure for over an hour) and bleed the brakes.
Today I tore everything apart caliper and all on the right rear just to see if it was bad. But I didnt see anything abnormal. So I pressure tested the system again and this time there was no leak. However, I noticed a drip on the drivers side after everything was complete but the passenger side was fine.
When I bleed the brakes there are ZERO bubbles in the fluid with a firm pedal.
Im starting to think that when I go to bleed the brakes using the bleeder that some leaks by the clear hose and runs down the back side of the caliper. This would explain the NO loss in pressure or ZERO bubbles when bleeding. Therefore the small leak I think I am seeing is just residual fluid from the bleeding process when I remove the clear hose from the bleeder.
Anyone see this happen before?
One other note I bleed each caliper 3 times to make sure all the bubbles were out of the system. Its more than possible that some fluid came out of the bleeder/hose when I disconnected the hose from the bleeder.I am starting to think this has been the cause all along.
The exact same thing you've describe happened to me and that's exactly what it was, a little gets past the clear tubing when you remove it from the bleeder.. I wiped mine down really good afterwards but probably a drip or two can get by.
Thats good news! Glad im not the only one.
If something was wrong with the caliper I assume I wouldnt hold 10 psi for over a hour when pressure testing and I wouldn't be able to get the air bubbles out of the lines/caliper.
