Motive Power Bleeder Question.
Old Feb 14, 2016 | 01:07 PM
BEVO76's Avatar
BEVO76
Default Motive Power Bleeder Question.
Getting ready to bleed the brakes this week. Does the metal plate that goes over the master cylinder / brake fluid reservoir actually work or do I need C-clamps? I have seen some use both methods, but I want to make sure I have everything I need before I start. Im used to having the wife pump the pedal for an hour. Apperently this is much easier......we will see!
Old Feb 14, 2016 | 01:28 PM
1Fordman's Avatar
1Fordman
I used a big c clamp with mine, it was easier to use than the chains on the top plate.
Old Feb 14, 2016 | 01:37 PM
Bloodzone's Avatar
Bloodzone
+ Vote for C-Clamp.
Old Feb 14, 2016 | 01:55 PM
ddawson's Avatar
ddawson
C Clamp. Less mess because you get a tighter seal.
Old Feb 14, 2016 | 02:32 PM
jimkari's Avatar
jimkari
I just bled my '73 with the Motive Pressure Bleeder and it worked great. I really struggled in the past to get a firm pedal due to the dual bleeders. The Motive system was really quick, basically just the time it took to remove and replace the wheels. Once I pressurized the tank it held enough pressure for all four wheels. I too used two clamps to hold it on instead of the chains. One bit of advice, be a little careful when you release the pressure. Good luck.
Old Feb 14, 2016 | 02:49 PM
BEVO76's Avatar
BEVO76
Awesome great tips....thanks for the heads up.
Im guessing you just pressureize the system with the tank and then open the bleeders one at a time untill there are no more bubbles and then close the bleeder.
How often were you filling the reservoir when you were bleeding or does the tank manage that piece?
Old Feb 14, 2016 | 02:53 PM
BEVO76's Avatar
BEVO76
If the tank when pressurized keeps the reservoir full did you have to suck some out when you were finished?
Im assuming this is the tricky part when you release the pressure? How did you do it? Can you just slowly unscrew the tank cap to let the pressure out? That would make sence to me.
Old Feb 14, 2016 | 03:13 PM
Bloodzone's Avatar
Bloodzone
Tank will keep reservoir full as long as you have pressure and enough fluid in tank. Release pressure from tank and disconnect power bleeder when done. I've not had to remove any excess fluid after releasing pressure. But she is full to top. I think a small amount of fluid gets pull back into bleeder when you remove pressure.
I would make sure I had plenty of fluid in tank to do all four before I started. Fluid is cheap
Old Feb 14, 2016 | 03:50 PM
ykf7b0's Avatar
ykf7b0
Use a large c-clamp. I do not put fluid inside the tank but I do top off the reservoir after doing both rears and before moving up to the fronts.
Old Feb 14, 2016 | 07:52 PM
flyeri's Avatar
flyeri
Clamp is the way to go. Small piece of wood on the bottom to protect the master cylinder and I use a piece 2x4 or angle iron across the top. It keeps the pressure back to front even.
Old Feb 14, 2016 | 08:02 PM
oldpainter's Avatar
oldpainter
C-clamp is the best route. Wish I had that 30 years ago...
Old Feb 14, 2016 | 08:10 PM
BEVO76's Avatar
BEVO76
Thanks for all the tips guys. Glad I asked because I was going to use the clamps that it came with.
I will pick up two large C clamps this week. Or I might get some of those pistol grip wood clamps.
Old Feb 14, 2016 | 08:47 PM
C3 4ME's Avatar
C3 4ME
I used 2 construction wood clamps instead of C clamps, but they worked great. I too don't put fluid in my can because my Vette uses DOT 5 and my others use DOT 3, and I don't want to have to clean it out completely every time. Great tool btw, and it gave me the best brakes my 79 has ever had.
Old Feb 14, 2016 | 09:06 PM
Kim72's Avatar
Kim72
Just so I'm clear: you don't have to put fluid directly into the tank itself? So it's just air pressure doing the job? If so, this would help in clean up and safety of the paint.
Old Feb 14, 2016 | 09:07 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I have the professional Aamco Brake Bleeder.. (I actually have two of them) and a long long long time ago I made lower plates with bolts and wing nuts to attach it to the master cylinder... Why? Because no matter how tight we got the chains the darn things would leak.
I ditched the goofy chains for a better design and it never leaks now. I'm not familiar with how yours would bolt on.. But I will say that when you turn on the pressure if you hear any hissing at all you've got a leak.
Old Feb 14, 2016 | 09:34 PM
BlackC3vette's Avatar
BlackC3vette
It may leave the level slightly higher than you want. Stop and pick up a cheap turkey baster to remove any excess.
Old Feb 14, 2016 | 09:42 PM
BEVO76's Avatar
BEVO76
Funny you say that....the wife just left for the store and I told her to get one....lol.
Im going to fill the tank seeing I replaced the entire rear end this winter. The calipers were off and drained so there not much fluid in them. I dot want to run the resivoir dry.
To Motive Power Bleeder Question.
Old Feb 14, 2016 | 10:01 PM
BlackC3vette
I hope you didn't ask her to pick up c-clamps too.
Old Feb 14, 2016 | 10:26 PM
ykf7b0's Avatar
ykf7b0
You got it. It is much less messy without filling the tank and the air pressure is all you need to do the job. I pressurize the tank at 15 psi and let it set for a couple of minutes to make sure I have a great seal with the c-clamp.
Old Feb 14, 2016 | 10:44 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
If you have a newer style motive I suggest using air line quick connects. I did that in mine so if I need to refill the master I can just quick disconnect the bleeder. This keeps the pressure in the tank so I don't have to pump it up as much.
