Van Steel spring failure
Old Feb 14, 2016 | 04:06 PM
AirBusPilot's Avatar
AirBusPilot
Default Van Steel spring failure
Was losing ride height, and ride was getting progressively worse. Took it for a drive after it sat for a few months and got high centered on a low speed bump. Took it home and found this:
Old Feb 14, 2016 | 04:07 PM
redvetracr's Avatar
redvetracr
nothing lasts forever but how old is that spring?
Old Feb 14, 2016 | 04:09 PM
AirBusPilot
I have no idea how this happened. Just have to figure out what these numbers mean. I bought the car with this already installed.
Old Feb 14, 2016 | 04:10 PM
AirBusPilot
I'd say less than 5 years.
Old Feb 14, 2016 | 04:26 PM
BEVO76's Avatar
BEVO76
Dang that sucks!!!
I heard these can fail from time to time and are not as strong as the 9 or 7 leafs. I was on the fence for a while between composite and steel.
Glad I chose the F41 7 leaf from Duntov. Something to consider when you go to replace it.
Old Feb 14, 2016 | 05:09 PM
jb78L-82's Avatar
jb78L-82
I have had my vbp 360 monospring on my 78 since 1986......there is a really good reason why GM has not used steel transverse leaf springs on corvettes since 1982....
Old Feb 14, 2016 | 05:46 PM
Tampa Jerry's Avatar
Tampa Jerry
Default Spring
Is it possible that the exhaust was too close to the spring and or mount? That would do it. Jerry
Old Feb 14, 2016 | 05:58 PM
BOOT77's Avatar
BOOT77
Actually composite springs are suppose to last a long time and hold their value. Unless it was damaged physically/heat or installed wrong and since you didn't install it you may never know really. I would have inspected it the moment it started to drop in height, since composite springs hold their value forever that is a sure sign of impending failure.
Since you can see the plate is bent I'd almost say it was over torqued. Still idk the break could have release stored energy and those plates are pretty flimsy. I bought the so-called VBP heavy duty one to replace the bent stock plate that came off my car and the new HD VBP bent on the 2nd time I checked torque with the new composite spring and I know my torque wrench is accurate!
Old Feb 14, 2016 | 05:59 PM
BOOT77's Avatar
BOOT77
Unless he dropped the exhaust before the pic that is a pretty big air gap.
Old Feb 14, 2016 | 06:04 PM
ignatz's Avatar
ignatz
I was curious about that too. If they're normally up near the mount that spring has been heat soaking all of its life. My exhausts run outside the center area and I've a nice heat shield between the exhaust and spring (which is maybe 25 years old by now)
Old Feb 14, 2016 | 06:38 PM
AirBusPilot
I did drop the exhaust in order to get the spare tire carrier out.
I suppose it could have been the exhaust, but I don't think it is placed any closer than anyone else's.
I've heard these springs can last forever, but I have no idea what went wrong.
Probably going to order a new one from VanSteel tomorrow.
Old Feb 14, 2016 | 07:14 PM
BOOT77's Avatar
BOOT77
Well then it could be heat.
I use a Muskegon brakes heatsheild for my c3, they are cheap. The rubber blocks were both tapped on top when I got the spring and I may move one to the bottom to space the heatsheild some.
Here I made one out of some Thermo-Tec heatsheild stuff for my C4 and attached it to the exhaust itself, it's not the best idea because it can transfer some heat thru the bracket but I think it's better than nothing.
And I just found this double heatsheild pic in an old thread from 2006. I was looking for more pics after noticing the smart-strut kit has more center exhaust clearance than the dragvette kit as you can see in pic1 vs pic3. So now I may use a VBP kit since my exhaust hits on everything and think I'll copy the double shield since it'll be closer to the spring. See where the guy drilled & tapped the four bolt heads.
Old Feb 14, 2016 | 07:24 PM
AirBusPilot
Thanks!
Old Feb 14, 2016 | 08:04 PM
BEVO76's Avatar
BEVO76
I dont disagree. However, I like the extra 30lbs along the half shafts for extra grip on take off. Then again I bang on mine pretty hard.
Old Feb 14, 2016 | 11:08 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
327 lb.
Part #
1/2" off each end(for tire clearance)
Old Feb 15, 2016 | 06:13 AM
theandies's Avatar
theandies
Originally Posted by Ed T
here is a TRW spring, maybe 9 yrs old, nothing neglected on this car. Heard a big "crack" sound pulling into my driveway......sometimes stuff just happens, get out the checkbook.......again
My VBP spring did that (not as bad) less that a year of it's install. Dan at VBP was great working with and I had a new one right away. That one has been in the car almost 10 years not without a problem. I don't have a heat shield installed but put some header wrap on my pipes that run under the spring. It appears you don't have that problem with sidepipes.......BTW hows the hearing out of your left ear? I took my sidepipes off because of that.
Old Feb 15, 2016 | 09:06 AM
AirBusPilot
Originally Posted by claysmoker
327 lb.
Part #
Alright, Alright, Alright!
To Van Steel spring failure
Old Feb 15, 2016 | 09:27 AM
jb78L-82's Avatar
jb78L-82
Understood. The composite takes about 40 lbs off the rear but on my 78 the weight distribution totally stock from the factory was Front 48%: Rear 52% which is pretty much ideal for handling and pretty good for traction. On my car, I have probably taken 100 lbs of the front as well with no AC compressor, aluminum heads, no AIR pump and plumbing, no cast iron exhaust manifolds so I am figuring about F49%:rear 51%. Anything you can do to lighten the car is a benefit...If you need traction, start with great tires which means 17/18 rims and ZR rated ultra high performance summer only tires with AA traction rating.
Old Feb 15, 2016 | 10:04 AM
jb78L-82's Avatar
jb78L-82
Yes, you should have a heat shield whether the OEM one or make one yourself...the OEM steel spring had a heat shield on my 78 and I reinstalled it when I put on the composite in 1986....Seems like lots of folks discard the heat shield when they install composites or their C3 did not have one from the factory. You should definitely have something between the exhaust and the composite spring...You can go to home depot/lowes and get a plain sheet of aluminum to make a shield relatively easy...
Old Feb 15, 2016 | 10:11 AM
AirBusPilot
I just placed my order with VanSteel. Having it sent overnight. Any installation tips?
