Fusible link
Old Feb 15, 2016 | 04:51 PM
Sayfoo's Avatar
Sayfoo
Default Fusible link
2 fusible links at my horn relay are really ugly. The wire seems intact and everything works, but the rubber jackets are deformed/melted?
I can find 16ga replacements, but not 20ga. Seems to be a odd ball size?
Any one have a source?
Old Feb 15, 2016 | 06:20 PM
carriljc's Avatar
carriljc
Default check o'reillys
i just looked and they have 16 gauge fusible links.
Old Feb 15, 2016 | 08:23 PM
flyeri's Avatar
flyeri
Are you protecting a 16 gauge circuit?
Old Feb 15, 2016 | 08:28 PM
Sayfoo's Avatar
Sayfoo
One original link is a 20ga as shown in 3 different wiring diagrams.
I would like to replace it with as close to factory original as possible.
12,14,16,18 gauges are readilly available at most parts stores.
Old Feb 16, 2016 | 09:47 AM
7T1vette's Avatar
7T1vette
The GM wiring diagrams show the fusible links as length of wire with large black dots connecting to regular wiring. They also specify the size of the regular wiring and the size of the links. Use what is called out on your diagram. Also, use only correct fusible links...ones that have non-flammable insulation and connecting terminals. The intent of the fusible link is that the smaller wire in the link will burn/melt before the larger regular wire in the circuit and force loss of power (to save damaging major components). But hot wire will cause normal plastic insulation to catch fire. Insulation and terminals on a fusible link MUST NOT BE FLAMMABLE.
Install fusible links...not fuses or circuit breakers. The smaller wire can handle very short bursts of high current without damage; fuse/breaker will just trip.
Old Feb 16, 2016 | 12:44 PM
Sayfoo's Avatar
Sayfoo
OK, thanks for all the replies, BUT the question is, does anyone have a SOURCE to buy 20 ga fusible links or wire?
Old Feb 16, 2016 | 01:32 PM
SH-60B's Avatar
SH-60B
Summit racing.
Old Feb 17, 2016 | 01:17 PM
Sayfoo's Avatar
Sayfoo
Originally Posted by SH-60B
Summit racing.
Yes, thank you, I saw this, and it may be what I end up with.
The original is orange, which is NOS only for $$$ for a 50' roll.
Old Feb 17, 2016 | 08:41 PM
SH-60B's Avatar
SH-60B
http://www.summitracing.com/parts/pco-5557pt/overview/
Old Jul 26, 2016 | 12:12 AM
Omarsvette's Avatar
Omarsvette
I have the same issue. How do you connect the wire
To Fusible link
