Shift Flash Light
Old Feb 17, 2016 | 08:38 PM
ex9850's Avatar
ex9850
Default Shift Flash Light
I am looking into installing a shift light. Anybody have one in their C3? Tell me about it.
Old Feb 17, 2016 | 11:46 PM
keithinspace's Avatar
keithinspace
I'm thinking about one also.
My understanding is that since I have a MSD 6AL box, wiring one up gets really easy really fast.
If you are using a non-box system, I'm sure there are ways to back into it...
Old Feb 18, 2016 | 06:22 AM
Street Rat's Avatar
Street Rat
I've got an Auto Meter Pro shift lite mounted to my steering column. Three wires is all it takes. Red=switched 12v source. Black=ground. Green=tachometer signal from tach terminal on distributor. My shift lite has the replaceable "pills" to change the rpm setting.
I have the factory tach and HEI. This was probably one of the easiest mods that I have done.
Good luck and happy shopping.
http://www.ebay.com/itm/Auto-Meter-P...lWNjo~&vxp=mtr
Old Feb 18, 2016 | 11:50 AM
Doug Kraft's Avatar
Doug Kraft
I put the shift light and a 15lbs low oil pressure light on mine, just in case.
Old Feb 18, 2016 | 01:27 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
One thing I know about shift lights is to set them a few hundred RPM's below where you want to shift as it takes time from the time you see the light to react, let off the gas and shift.
Old Feb 18, 2016 | 11:08 PM
Solid LT1's Avatar
Solid LT1
When my wife 1st drove my 72 LT-1 at the Drags, I told her to shift it around 7K RPMs later while talking to her I asked her where she was shifting it....her reply, I don't remember, I just watch the other car and if they are gaining on me I shift it, the motor would still pull at 7200 RPM but, I was not planning on using the excess. The following week, I installed a rev limiter set at 7250RPM and shift light set to 7K. My wife then told me the light flashing while autocrossing the Vette bothered her, I told her shift it up another gear and your problems will go away!
Old Feb 19, 2016 | 08:09 AM
69ttop502's Avatar
69ttop502
Now that is funny!
To Shift Flash Light
