Damn more work.
Old Sep 1, 2002 | 05:56 PM
dogboy's Avatar
dogboy
Default Damn more work.
I just did the cam swap and replaced the timing cover with a chrome 2 piece thinking. "Oh how great if I need to access gears or swap cam again it will be so much easier". Well the damn thing leaks from the rubber seal area against the oil pan. wth. I should have read the earlier posts about these cheap covers beforehand. Hindsight bites. I think I'll put back on the original cover.
Old Sep 1, 2002 | 07:07 PM
jerryp58's Avatar
jerryp58
Default Re: Damn more work. (dogboy)
Hang in there, you'll get it :yesnod:
Have you had a chance to check out the new cam?
Old Sep 1, 2002 | 07:18 PM
dogboy's Avatar
dogboy
Default Re: Damn more work. (jerryp58)
The cam kicks in strong when the secondaries open. It feels like a different engine. I noticed the sound is a LOT stronger throughout the rpm range. I probably need headers to get the exhaust out like it should. I'm running duals now. Idle is somewhat lumpy and once I get my recurve kit in it should be even stronger. I'm a little dissapointed with the out of the hole pick up. even with the mild TC (18-2200); 3:08's don't help much either.
To Damn more work.
