Greasy Front Suspension
Old Feb 19, 2016 | 09:06 PM
xpoc454's Avatar
xpoc454
Default Greasy Front Suspension
Could someone explain to me any locations on my front suspension that do not need heaping amounts of grease on it? I am getting tired of working under my car and coming out all covered in grease and oil.
Where are the locations that should have grease on it and which are just places that are just road grime and grease and can be wiped off?
thanks
Old Feb 19, 2016 | 09:17 PM
Wee's Avatar
Wee
Other than places like inside the rubber boots of the ball joints you can clean up just about any of the grease you want....Be prepared....It's a messy job.
Brian
Old Feb 19, 2016 | 09:29 PM
xpoc454's Avatar
xpoc454
I guess I am going to have to do it, my arms and my clothes have only done so much of the grease removal :P
Old Feb 19, 2016 | 10:56 PM
Wee's Avatar
Wee
Here is a link to a post where I asked advice on cleaning up the underside...Might give you some ideas.
Brian
Old Feb 19, 2016 | 11:25 PM
7T1vette's Avatar
7T1vette
Find a shop that does steam cleaning. They will put it on a lift and steam clean the entire underside in less than 30 minutes. It won't be clean enough to paint, but it will be free of piles of grease, dirt, rocks, mud, etc. Parts will only requre some final prep with solvent wipedown and water soluable cleaner/rinse before painting. And, the bulk of the underside is fiberglass which does NOT require painting (not painted from factory).
You might want to remove the spare tire and tub before taking it there. Also, think about how many hours of tedious work and cans of degreaser you would need to DIY it. If you figure your savings per hour (based on DIY time) to justify the cost of that job, it's a no-brainer to have it done and save you a TON of grief.
Old Feb 20, 2016 | 09:29 AM
midigike's Avatar
midigike
Originally Posted by Alan 71
Hi x,
One thing that you'll need to be aware of if you decide to "de-grease" the front suspension or other areas of the suspension or chassis is that many of those metal parts that have been "protected" by that layer of grease/grime will begin to rust.
That's not a problem on many parts, but is on some, so it's something you should at least be aware of.
If you were to "de-grease" under there you may want to still protect it all with a product like Pre-Lube 6 or something similar. That will stop much of the rust from forming but will give you a much cleaner 'place' to work under there.
Regards,
Alan
Being mine has a greasy underside, I like to refer to the grease as the Corvette anti-corrosion measure
Old Feb 20, 2016 | 01:03 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Hi x,
Regards,
Alan
I agree with the rust preventing properties of 40 years of road grime / grease under your Vette.
Old Feb 20, 2016 | 01:16 PM
xpoc454's Avatar
xpoc454
I'm doing something correctly. Mybwide kicked me out of the hiuse. She said I smelled like "car".
To Greasy Front Suspension
