Moving dist for better tach connection
Old Feb 22, 2016 | 12:59 PM
spf72's Avatar
spf72
Default Moving dist for better tach connection
the bend in the tach cable is extreme in its standard position. I want to move the distributor one position for easier cable hook up. I don't believe the engine cares as long as the wires are in the right place.
Can I just set it at TDC, pick the distributor up move it one position and then move all the wires one tower over?
Old Feb 22, 2016 | 01:16 PM
ignatz's Avatar
ignatz
Sounds to me like you've already figured out what to do. They also sell these
http://www.ebay.com/itm/Corvette-Tach-Tachometer-Cruise-Control-Cable-Adapter-90-degree-1953-1982-/191764413425?fits=Model%3ACorvette
Old Feb 22, 2016 | 01:21 PM
Paul L's Avatar
Paul L
Yes.
Old Feb 22, 2016 | 01:25 PM
kanvasman's Avatar
kanvasman
go for the 90 degree adapter. Works perfectly and you don't need to change anything else.
loquinho's Avatar
loquinho
You have independently come to the same conclusion as GM did. They released a service bulletin describing this exact procedure. Here's the photo - not mine, and not sure who took it originally.
*edit: Took down the photo since Paul 74 beat me to it.
Old Feb 22, 2016 | 01:36 PM
lars's Avatar
lars
Don't use the 90-degree adapter. It puts additional torque load on the crossgear, which will cause the gear to dig itself into the thrust wall of the distributor housing, seize up, and strip out. This will cause several hundred dollars in damage due to the machine work needed to save the housing after the adapter has been used. I've had to repair over a hundred of these, so I've seen the consequences... Just rotate the distributor per the GM Service Bulletin - it solves the problem.
Lars
Old Feb 22, 2016 | 02:03 PM
crisko's Avatar
crisko
I installed 1 of the adapters about 8 years ago .Haven t had a problem.
Old Feb 22, 2016 | 02:13 PM
spf72's Avatar
spf72
Thanks for the diagram. I have one of the adapters and it caused issues in the past. Seems easier to just move the distributor.
Thanks again.
Old Feb 22, 2016 | 02:27 PM
Paul L's Avatar
Paul L
Thanks again.
It works.
Old Feb 22, 2016 | 02:41 PM
spf72's Avatar
spf72
Is my sequencing right on how to move it? Does it really matter to bring it to TDC or can you do it from wherever the distributor happens to be? Is a move a move regardless of where you start? Also, do you need to move the oil pump fitting with a screwdriver or will it just align on its own?
Old Feb 22, 2016 | 04:19 PM
lars's Avatar
lars
You never remove the distributor. You just loosen it, rotate it 45 degrees, and move all the plug wires over 1 tower. You'll then need to recheck your timing, of course.
Lars
Old Feb 22, 2016 | 04:20 PM
lars's Avatar
lars
I'll bet you haven't put 50,000 miles on the car...
Old Feb 22, 2016 | 09:07 PM
rcread's Avatar
rcread
I always look at your pictures and think to myself "Oh, that's how mine is supposed to look."
Originally Posted by Alan 71
Hi spf,
This is to reiterate Paul 74's positioning including where he has the #1 plug wire.
Regards,
Alan
To Moving dist for better tach connection
