80 Corvette Door Locks
Old Feb 24, 2016 | 12:05 PM
76yellow's Avatar
76yellow
Default 80 Corvette Door Locks
Why are my door locks hard to move ? The electric ones do not work but I don't really care about that. The problem is I need a needle nose to move the manual *****. Did they move freely from the factory ?
Old Feb 24, 2016 | 12:53 PM
Street Rat's Avatar
Street Rat
Lubricate all moving parts and the work them. My car sits outside and I have to frequently do this. You may even take the door panel off to get to things.
Old Feb 24, 2016 | 02:44 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Did they move freely from the factory?...
With power locks, the switches and actuators do all the work. The actual lock ***** in the armrests are a fail safe. You can expect a little resistance, but not to the point where you have to use a pair of pliers.
I agree with Street Rat. Sounds like time for cleaning and lubing.
Old Feb 24, 2016 | 07:54 PM
DUB's Avatar
DUB
If you want you door lock ***** and UNLOCKING your door with the KEY to be done easily....then you have to EITHER....replace the door lock actuators with NEW ones OR go inside the door and remove the linkage from the door lock actuator from the locking linkage.
The reason you are having such a hard time is due to crap being inside the door lock actuator....and that will not change unless they are disconnected or replaced...or removed.
I have tried applying an oil to free up the tension in the door lock actuator...but that seems to be a pointless waste of time because the rubber boot that is supposed to keep crap out of the moving parts and allowed stuff to get into it and that is where the problem lies.
AND...for what this is worth. If a person is going to replace the door lock actuators....KEEP IN MIND that even if they are NEW....they can be CRAP. A Corvette is fiberglass/SMC and IF when you get a NEW actuator...and you manually grab the shaft of the actuator and it is hard to move...then what do you think is going to happen when you try to UNLOCK your door with the KEY. The actuators I use you can grab the shaft and it take NO EFFORT to move it in and out...so when I install it and try the door key...I an NOT fearing that I will either BREAK the key off in the lock cylinder....or actually SPIN the lock cylinder in the door.
DUB
Old Feb 25, 2016 | 02:56 PM
SwampeastMike's Avatar
SwampeastMike
The lock mechanisms in my '79 were so stiff that essentially nothing worked no matter how hard you tried.
The problem was SEVERE need of cleaning and lubrication. Yes, you must remove the door panels to do this but it's an easy job. Essentially you remove and clean every piece then lubricate with white lithium grease.
After doing this to mine everything moves freely and the original door lock actuators work perfectly. The actuators were the only things that weren't gummed up. I did however replace the rubber boots around the actuator shafts as they were in tatters. While not exactly the same, the rubber boots used on our headlamp operators work fine.
Old Feb 25, 2016 | 07:21 PM
DUB's Avatar
DUB
Because I do this for a living...taking the time to try to lubricate the actuators...which I have tried just for fun...is almost a 'hit or miss' scenario.....so I just put new ones in and move on.
BUT I do lubricate all related parts inside the door when I am there.
DUB
Old Mar 22, 2016 | 02:09 PM
Elba Mike's Avatar
Elba Mike
St. Jude Donor '16
Is there any "secret" fasteners or tricks to use on the door panels of an '81? I need to take mine off, and don't want to break any clips.
Old Mar 22, 2016 | 02:44 PM
Easy Mike's Avatar
Easy Mike
Trim screws. Armrest screws. LH mirror joy stick. Possibly one or two retainer clips. Do you have the AIM? AIMs are handy to have around.
Old Mar 22, 2016 | 02:49 PM
Elba Mike's Avatar
Elba Mike
St. Jude Donor '16
I do have one. I'm not near it now though. Seems I always break something taking door panels off, clips and things.
To 80 Corvette Door Locks
