1973 Flasher Upgrade (LED)?
Old Feb 24, 2016 | 07:06 PM
TheJinx's Avatar
TheJinx
Default 1973 Flasher Upgrade (LED)?
So I have a 1973 Corvette & I bought an LED Flasher. I'm trying to install it on the passenger side. Problem is I have nowhere to ground the ground wire due to the car being fiberglass. Any solutions on where I can ground the wire to the passenger side flasher? Does anyone have pictures of how they did it to theirs? Anything helps! Thank you!
Old Feb 24, 2016 | 07:14 PM
'75's Avatar
'75
You could remove the kick panel and run a ground wire to one of the screws in the birdcage.
Old Feb 24, 2016 | 07:15 PM
'75's Avatar
'75
I don't remember the brand of electronic flasher I used, but it didn't need a ground wire.
Old Feb 24, 2016 | 10:01 PM
Solid LT1's Avatar
Solid LT1
There are plenty of metal surfaces around between the "birdcage" and underdash supports to ground to in that area, use a test lamp or voltmeter to find a good location.
Old Feb 29, 2016 | 02:50 PM
babbah's Avatar
babbah
At any Parts Store:
Blazer brand. model FL32 $10
(goes under other model numbers as well - same flasher)
To 1973 Flasher Upgrade (LED)?
