1980 battery light
Old Mar 1, 2016 | 10:08 PM
cb.bums's Avatar
cb.bums
Default 1980 battery light
replaced all under hood wiring. battery light stays on. had alternator checked. reads good. also battery is new, but runs down in two weeks of sitting. help
Old Mar 2, 2016 | 07:18 AM
BlackC3vette's Avatar
BlackC3vette
My immediate concern would be who checked the alternator?
Old Mar 2, 2016 | 09:45 AM
cb.bums's Avatar
cb.bums
autozone. thanks for the wakeup call.
Old Mar 2, 2016 | 11:19 AM
BlackC3vette
When running, is the battery light on full brightness like it is when the key is turned on or is it dimly lit?
Old Mar 2, 2016 | 12:04 PM
cb.bums's Avatar
cb.bums
bright. Never dims
Old Mar 2, 2016 | 10:02 PM
BlackC3vette
bright. Never dims
What is the voltage at the battery terminals with the engine running at idle or just above an idle?
Old Mar 3, 2016 | 08:15 PM
cb.bums's Avatar
cb.bums
will check Saturday. thanks
Old Mar 4, 2016 | 08:14 AM
BlackC3vette
While your checking, see what the voltage is to the brown wire on the alternator plug. It will be the wire from the ignition switch with the battery light in the circuit. Check it with the key on. There are only 2 wires in the plug, the smaller diameter wire is from the ignition. I am at work now so I can't run out to the garage to check the color.
Old Mar 6, 2016 | 05:08 PM
cb.bums's Avatar
cb.bums
well, the alternator voltage reads at 14 at the battery. the voltage at the alternator reads 14. ran a ground from alternator to frame, light stays on more dim now. could it be a bad ground from battery to frame?
Old Mar 6, 2016 | 07:56 PM
BlackC3vette
Do you have an engine to frame ground wire? Mine is fastened to the block on the passengers side.
With 14volts, the alternator is putting out pressure, it would be nice to know how much amperage was flowing. Any chance to borrow a clamp type ampmeter?
Did this problem just start?
It would be nice if some other members jumped in with troubleshooting suggestions.
Old Sep 18, 2016 | 09:44 PM
M Pete's Avatar
M Pete
Did you ever find your problem? I have an '80 and similar issue. Battery light stays on with key out. While running it is not on. I'm going to have the alternator checked out this week.
Old Sep 19, 2016 | 08:52 AM
stingr69's Avatar
stingr69
I would tear down alternator to check "diode trio" with ohm meter. Small chip looking thing. Needs to have continuity in only one direction. If continuity flows both ways, you need to replace diode trio. Cheap and easy fix.
Diode bridge is different and is used to generate power to recharge battery. Diode bridge is larger rectangular heat sink looking thing with 3 studs wires and nuts... but I bet it is working fine as you have plenty of running voltage.
Diode trio only functions to light the dash light when alternator is not charging... and yours IS charging when engine is running so it works fine.
You have current flowing thru that circuit one way or another.
Old Sep 19, 2016 | 06:54 PM
SIXFOOTER's Avatar
SIXFOOTER
So you changed the underhood wiring....first clue
unplug the 2 wire connector from the alternator, does the light still come on? If so you ave a wiring issue. The light is powered in the dash circuit and the ground side of the lamp provides voltage sensing. If the sense side of the alternator fails it will turn on the light.
Old Sep 19, 2016 | 07:48 PM
cb.bums's Avatar
cb.bums
found that the ground wire cover melted and was grounded to the exhaust manifold.
Old Sep 19, 2016 | 08:20 PM
cb.bums's Avatar
cb.bums
forgot to mention a still wired in non functioning aftermarket alarm.
To 1980 battery light
