79 L48 Valve stem seal
Old Mar 6, 2016 | 01:41 PM
newbie2vette's Avatar
newbie2vette
Default 79 L48 Valve stem seal
I finally finished cleaning and porting the cylinder heads on the 79 with L48 I am reviving. After lapping the valves and began to assemble the valves, during the process of installing the spring and associated parts. I noticed the valve stem seal gets pushed down below the grove it is supposed to be on. What's the affect if one is not in the grove?
Old Mar 6, 2016 | 02:01 PM
GOSFAST's Avatar
GOSFAST
Assuming you mean the small "O" rings below the keepers??
If so, they get installed AFTER the springs and retainers have been "compressed", just before installing the locks.
Thanks, Gary in N.Y.
P.S. Here's a shot of the pieces in order as they would be on the heads.
Old Mar 6, 2016 | 02:17 PM
newbie2vette
Boy do I feel like an idiot. I installed the "o ring" then the spring over it. Thank you.
To 79 L48 Valve stem seal
