Crossfire running query
Old Mar 8, 2016 | 03:49 PM
bigfella70's Avatar
bigfella70
Default Crossfire running query
Hi guys
Been to have a look at an 82 collectors here in the uk.
One query I have is that the tickover seems a little high.
Also (and my main concern) is that when blipping the throttle it seems to delay in dropping down to tickover speed. Almost like a sticking throttle.
Question is are these on a cable throttle or "fly by wire" set up. How easily adjusted is the tickover and what could be causing it to delay in dropping back to tickover speed ?
Any advice appreciated !
Regards.
Dave
Old Mar 8, 2016 | 05:18 PM
toobroketoretire's Avatar
toobroketoretire
Originally Posted by bigfella70
Hi guys
Regards.
Dave
The delay is caused by the IAC motors screwing their pintle valves in and out and that's normal for the CrossFire Injected engines.
Old Mar 9, 2016 | 01:22 PM
bigfella70's Avatar
bigfella70
Ah thanks so it sounds normal behaviour then.
Cheers
Dave
Old Mar 10, 2016 | 08:15 PM
terry82's Avatar
terry82
does this change any when the motor is cold or hot.what temp is the car running at.a cold motor will run a higher rpm.
Old Mar 11, 2016 | 09:02 AM
454Luvr's Avatar
454Luvr
Mine runs higher (a little above 1K) when the engine is first started. It takes about five minutes to slow to a normal idle speed, longer if the weather is cold.
Old Mar 11, 2016 | 02:10 PM
bigfella70's Avatar
bigfella70
Thanks all, the idle was high in general , hot and cold also delayed dropping to idle after blipping the throttle . However, annoyingly the car I was looking at has sold whilst I went away to think about it and do some research ! Advice is worth knowing though so thanks very much for the help. I will get a Vette sooner or later ;-)
To Crossfire running query
