Body shifted?
Old Mar 9, 2016 | 03:59 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Default Body shifted?
I received my new 18" wheels and proceeded to test fit them sans tires. This brought up a problem I've ignored until now. The left front wheel is about 1" outboard when measured against the right side wheel. Here's how I came up with that. I used a level held vertically from the top of the fender arch and then measured horizontally into the top of the rim. The left side was 1/2" inboard and the right side was 1-1/2" inboard. Both rears measured equal so they are fine. You can easily see that the left front tire is more outboard than the right tire. The car drives straight, no uneven tire wear, never in an accident and when following down the road behind her, it's not **** eyed. Is it possible the body has shifted on the mounts? Everything looks fine on underneath.
Old Mar 9, 2016 | 06:22 PM
Alan 71's Avatar
Alan 71
Hi r,
Since there are 8 body mounts they'd all need to be pretty loose for the body to move…..plus things like the bumpers hold it in place too.
Have you checked to see if the front clip is loose?
Also, have you taken some measurements to locate both the wheels and body relative to the FRAME?
I think I'd check that next.
Regards,
Alan
Old Mar 9, 2016 | 06:24 PM
toobroketoretire's Avatar
toobroketoretire
Default Body Shifted?
Same with my '71 but it's only off by 1/2" in the front. Might be a tweaked frame causing it.
Old Mar 9, 2016 | 08:56 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
There is room for this kind of shift considering the body mount holes at the front position of the frame are 1 3/16". But as Alan mentioned, it'd be hard to imagine considering the other items that mount in place on the frame including the outer bumper braces on your 76.
Also.... if it shifted in the front it would have to shift in the rear too. Now you might be able to loosen all the bolts and tweak it but you'd have to give some in the rear to gain in the front.
I wonder if possibly someone didn't put a complete front end on the car and just didn't get it squared up during the install.
Willcox
Old Mar 9, 2016 | 09:23 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
I don't think it's the body mounts but I'll do some measuring just the same. Could there be something 'altered' somehow in a wheel alignment or in the front suspension? I'm sure the front end is all original and the car goes over bumps without any knocks or rattles. Could it have been born this way?
Old Mar 10, 2016 | 07:20 AM
69ttop502's Avatar
69ttop502
You could check the one hole on each side under the sill plates to see that the body and frame line up at those 2 spots.
Old Mar 10, 2016 | 03:53 PM
0Willcox Corvette
Former Vendor
Considering my 78 left the factory with a front bumper cover 5/8" away from the edge of the fender... I'd say yes possible but I doubt it... Hard to say to honestly.
Old Mar 10, 2016 | 07:23 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
Thanks for all the input thus far. I'll have some time tomorrow to start following up on your suggestions. My Michelin PSS tires arrived today. Can't wait to get them mounted next week.
Old Mar 10, 2016 | 09:27 PM
Gale Banks 80''s Avatar
Gale Banks 80'
I looking for clues as far as front end damage either frame or body. A 10 mph Hit Bends the Frame on these Cars all the Time. A lot of the time the Motor Mount brackets break loose from the frame when some minor damage has occurred the lower arm areas. Look for Non Factory Welds. They probably look to good, not worse than the originals. Then I would start looking at the Body Seems. Any Hand lay'd Fiberglass is a sure sign. Or odd colored Bonding Adhesive.
This being said when I put 17 C4 Wheels on my car in the late 80's I had to make my own Wheel Spacers and the front two were not the same. Maybe a 1/4" different, not as much as yours.
I have made up my mind that I'm going with the same Michelin Tire so I hope they work out. Just waiting for them to be available in my size.
To Body shifted?
