I read through the threads about rebuilding my power steering pump and took mine a part. I have a few issues. My shaft seal is a little smaller than the one included in the kit. It doesn't want to go in. Also I have these additional parts I didn't see in the pictures from this rebuild article. I'm wondering if I don't have different pump. http://www.corvette-restoration.com/...mp_rebuild.htm
The series of photos on rebuilding the Saginaw big, P-style pump look accurate. I think that you have the wrong rebuild kit. The Saginaw P-pump has been around for years and years. The one major design change occured in 1975 when the driveshaft changed to a interference fit pulley design.
Jim
The two parts on the right are an internal filter and filter retainer. This is usually discarded by pump rebuilding facilities. I recently ran across one of these and I cleaned it and reused it. RE: Seal- obviously, your kit does not match your pump.
How do I get the proper rebuild kit? What car did this probably come off of?
The pump came in at least 2 variations that I am aware of.
Shaft size - .750. .688 (or .687)
The OEM small seal for the .688 shaft is #5688020
This seal has a OD of 1.254 to press into a 1.250 housing.
I believe this crosses to a SKF #6765, National 8773S.
I can't tell you which kit will have this seal, but I know the Edelman #7910 kit is wrong because it has the larger seal for the later shaft .750. (ACDELCO #36348720 GM #19146402 which is 1.315 OD, shaft OD=.750)
My 66 has the small shaft.
My 70 has the large shaft.
Edit: The ACDelco kit #1914654 also has the larger incorrect seal.
Reason: Add info
I'm in the middle of rebuilding the power steering pump on my '71 350/270.
I also have the filter/element & the filter retainer. Are you suggesting I should discard these when doing my rebuild?
