turn signal problems
Old Mar 12, 2016 | 04:21 PM
cdw's Avatar
cdw
Default turn signal problems
hi,looks like i have the turn signal blues. turn lights on and everything works. have the pass. brake light only.no turn signal lights working. good grounds,fuses,bulbs. i cannot locate the turn signal flasher that is supposed to be on the pass.side. took the kick panel off and no flasher. there looks like a metal clip there with nothing in it. cannot see a flasher with my trouble light.two wires cut both green,p.o had a radio installed and these could be speaker wires.voltmeter showed 7.9 on driver side rear turn signal light. hazard flasher was cleaned and reinstalled. all hazard lights flash except rear markers. enclosed is a picture of an item that looks like the p.o. owner installed for whatever reason.it was installed on the wires from the brake light switch,i think orange and white. so now the fun begins. thanks guys
Old Mar 12, 2016 | 04:30 PM
toobroketoretire's Avatar
toobroketoretire
The capacitor is a factory-installed item that prevents damage to the points in the turn signal flasher. The early C3's had their flasher mounted on the front of the passenger side dashboard right below the vent and you can reach up and easily remove it. The later C3's had their flashers (two of them) mounted onto the upper face of the fuse block. One flasher is for the turn signals and the other for the hazard flashers and I don't remember which one is which.
Old Mar 12, 2016 | 06:29 PM
cdw's Avatar
cdw
Default turn signals
thanks for the reply. btw it's a 71 auto.hope i don't have to rehook the capacitor. only one flasher on the fuse block and i think it's the hazard.there is what looks like a ac duct right under the pass dash to the right side and i am having a tough time seeing past it.i still have not seen a turn signal flasher there. maybe i'll try to reach past the duct and see what gives. took the kick panel off and nothing there.i would like to locate the turn signal flasher and clean it off so i can cross that off as a problem.the hazard flasher works all the lights except the left rear marker.
Old Mar 13, 2016 | 10:56 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Here is my simplified schematic.
To explain the circuit... power to the tail lamps goes into the turn signal switch on the white wire. When you turn on the turn signal switch, power is pulled on that side from the white wire to the purple wire coming from the flasher and thus the flash. The side that is opposite stays powered up on the white wire.
So.. you'll need to find that purple wire and then start testing from there. Test continuity from the connector to the turn signal switch, then test it in and out of the switch by operating the switch. The capacitor is there to keep the turn signal static out of the radio, the system will function without it.
-Willcox
Old Mar 14, 2016 | 12:15 AM
Doug Kraft's Avatar
Doug Kraft
Question, What color wires in the harness turns on the interior turn signal indicator lights? Replaced left side dash pad and can't remember which is which. Tks
Old Mar 14, 2016 | 01:06 AM
Peterbuilt's Avatar
Peterbuilt
Dark blue for the right turn indicator in the dash.
Light blue for the left turn indicator in the dash.
http://www.vetteprojects.com/bmv/mis...tte%201976.pdf
Old Mar 14, 2016 | 10:55 AM
cdw's Avatar
cdw
thanks for the reply. i am making progress with the forum help.i now have brake lights. i am testing all lights and they have been dormant for about five years. did not have brake lights yesterday and re-grounded the rear and now they work.i still cannot locate the turn signal flasher. have removed the pass side dash and kick panel and have not seen what i call a flasher. i will be checking today again.i would assume the flasher is a round silver piece like i have seen for years. cleaned the hazard flasher and it works good. as soon as i locate the turn signal flasher i'll replace it. all new bulbs. thanks again
-Willcox
Old Mar 14, 2016 | 11:41 AM
cdw's Avatar
cdw
went out and looked at what might be the flasher.had two pinks and a violet wire. if this is the flasher,it looks like crap and looks like it's not all there. most of the flashers i have seen don't look like this.
Old Mar 14, 2016 | 11:53 AM
SH-60B's Avatar
SH-60B
No wonder you didn't reconize it, the cover came off. You need a new one.
Old Mar 14, 2016 | 05:23 PM
cdw's Avatar
cdw
Default turn signal flasher
got a new one today and installed it. everything works as it should.life is good again and i'm happy. will start on the interior lamps tuesday. probably will have some questions for that area.almost ready to get some seat time. thanks all.
To turn signal problems
