Caster shim question
Old Mar 16, 2016 | 10:58 AM
pawpaws toy's Avatar
pawpaws toy
Default Caster shim question
I was looking at the shim location on the A arms of my 1980 vette. The higher stack of shims are at the front. Wouldn't this be neg caster?
I thought they were stacked higher at the rear for pos caster.
Old Mar 16, 2016 | 12:14 PM
toobroketoretire's Avatar
toobroketoretire
When the shims are added in the front that pivots the top of the a-frame to the rear which tilts the top of the spindle backwards; increasing the inclination angle (positive caster). Adding shims in the rear pivots the top of the a-frame foreword which tilts the top of the spindle foreword and increases the negative caster.
Shims need to go wherever they are needed to make the geometry correct so sometimes you'll find more in the front and sometimes more in the rear depending on how your frame came out after fabrication.
Old Mar 16, 2016 | 03:08 PM
MCMLXIX's Avatar
MCMLXIX
The OP is correct.
The reply above was backasward at best.
Enginemanuring at its finest.
Old Mar 16, 2016 | 04:36 PM
pawpaws toy
Originally Posted by MCMLXIX
The OP is correct.
Thanks. No wonder the car wants to dart all around. Off to the alignment shop I go!!
Old Mar 16, 2016 | 08:04 PM
ddawson's Avatar
ddawson
Here this helps.
To Caster shim question
