Full Brake System Replacement
My options:
-VB&P kit SS with o-rings
-Vansteel kit SS with o-rings (comparable cost to VB&P)
-Ecklers kit SS with lip seal (about $100 less than the others)
-Cheap route Autozone etc...
All have a core charge, will any of them make good and give me the refund?
Any suggestions what might work best for me?
Have you contacted Willcox to see what type of brake package they offer?
To further my confusion I looked on Summit, they have kits by SSBC that are comparable to what I would be paying with the core deposits. Has anyone used these?
My options:
For calipers that don't leak, it doesn't matter the current stock of rebuilt / new units all have higher failure rates than those built before 2000's. Your original stock calipers will be the longest lasting units. Any replacement units you buy now, you would be lucky to get 5-7 years before they leak again.
There are a lot with the 2-3 years and no problems but that doesn't help a car that sits most of the time.
If you want "bling" you can look at wilwood kits (expect to pay for this) I dont know if there calipers are any better for leaking problems but I gave up on the corvette suppliers and I am on year 1 for wilwoods.
Of the two that sell products that they have done R&D with, both have had excellent customer service in the past and offered excellent tech service when you call them on the phone and are looking for advice on what works and what doesn't. Unfortunately one of them has recently received mention here on the Forum for having difficulty with their previously stellar customer service. I wish it weren't so, but I've watched this progress over the past few years and hope they can correct the problem.
I personally have purchased from all of them, and probably will continue to in the future when necessary. But one of them will always be my first choice.
If you have any questions, just PM me.
Good luck... GUSTO
What kind of warranty do they have for leak free ?
http://www.duntovmotors.com/brakes.php
I'm also a rookie with this type of system, I didn't think about this. How did you deal with it, machine shop?
http://www.kore3.com/proddetail.php?prod=10029-02
with their brackets 10637-01, for anyone trying to find these brackets you have to call or email them to order as they are not on their website.
You may run into 1 problem with the wilwoods in the rear when it comes to bleeding the brakes. Because the rear calipers are almost horizontol you may need to remove the caliper and place them upright to bleed properly. The bleeding screw position leave a air gap in the rear.
Saved 88 pounds , and she stops like a super car
