Stingray Emblem Removal
Old Mar 20, 2016 | 08:26 PM
Cavu2u's Avatar
Cavu2u
Default Stingray Emblem Removal
There are no Tinnerman washers holding the posts, so it appears that the emblem is held on with adhesive only.
I see the risk of breaking if I just start prying on it. Even if I pry on the emblem directly over the posts, it seems risky.
Now, it's coming off because of a complete strip & paint job, so I'm not overly concerned about damaging the paint in case a good working adhesive solvent is applied. I don't know which solvent works best.
Any thoughts on this will be appreciated.
Steve
Old Mar 20, 2016 | 08:31 PM
redrdstr72's Avatar
redrdstr72
Steve
FWIW, I've had complete success in removing the subject emblem by using fishing line, "sawing" the joint between adhesive and body. You'll need to re-start the process each time you encounter a stud/pin. Use of a heat gun might make it easier, however, I didn't want to risk damaging paint with heart so I did it without heat.
Old Mar 20, 2016 | 09:12 PM
Cavu2u's Avatar
Cavu2u
You, my friend, are a very smart cookie!
As far as your FWIW; One, and maybe even TWO broken emblems might cover it.
redrdstr72, thank you very much.
Steve
Old Mar 20, 2016 | 11:45 PM
Cavu2u's Avatar
Cavu2u
Heat gun and a single-edge razor blade did it.
Steve
Old Mar 23, 2016 | 04:26 PM
skyhawk50's Avatar
skyhawk50
Gotta love the CAVU. After the past few weeks, I'm ready for some CAVU.
" 3 greens over the numbers "
To Stingray Emblem Removal
